When I open the door on the driver side from inside the car, I had to open the lever right out in order for the door to click open. Sometimes I had to pull the lever open twice for it to click. It is likely that the cable is loose inside. Is it easy to fix this? Is it a common fault/recall that I can get audi to fix it for me. My cal is not under warranty anymore
What would be the cheapest so solution. I have The AA break down cover but I'm note sure if it includes this.
Any suggestions would be appreciated.
