Volks AutosAH Fabrications
Results 1 to 11 of 11
Thread: scuttle panel
    Ayrshire
    106
    scuttle panel
    Does the front scuttle panel need to be removed for the fitment off coilovers? If so how is it removed? Cheers
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    yes, sharp tugs does the job
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,773
    No it doesn't - I have managed several times between S/A3's to change the whole front suspension without taking the scuttle panel off.
    It's easy enough and saves you having to remove the wipers as well.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    what about the 3 bolts that are located under it?
    Mods
    Boydie's Avatar
    Boycie
    Dec 2006
    4,773
    Easily reached with a 13mm inch long socket and small ratchet spanner and finish off removal with your hands.
    It is easier of course to remove the scuttle panel but this saves time IMO!
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    haha i would imagine its a bugger to fit the new ones, never thought f going throught the honeycomb
    Mods
    Boydie's Avatar
    Boycie
    Dec 2006
    4,773
    I don't go through the honeycomb mate. I lift the front of the scuttle panel up at the front and there is enough room to get your hand and ratchet in to remove the 3 top mount bolts.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    ahh got you now mate wee bit of a irritating job getting the coils in on the three bolts?
    Mods
    Boydie's Avatar
    Boycie
    Dec 2006
    4,773
    It is not too bad - you can easily get the front or side one in to locate the top mount and then finger tighten the back one to line it all up once in position. Then tighten them all up with a small ratchet!
    As stated, it is easier to remove the wipers and panel but it is possible to do it without!
    26,776
    TBH I've done the lift scuttle up route many times, but it is a damn site easier to remove wipers which is a 3 minute job at most & remove panel as its only clipped in, 5-10 mins job at most, then do the job at hand & refit, cause you can easily snap the plastic panel lifting it up tbh & squeezing your hand & socket/spanner in there is a pita, when you can easily remove the offending parts til job done.
    Why I didnt do this before is beyond me I tell yer, I only realised 2 weeks back the poxy panel was clipped in place & lifted out so easy, was unreal.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    yeah its tough to get it to come out to begine with but after youve gotten it started its easy as pie
    Mods
