Boost Issue - Boost Pressure Regulation: Control Range Not Reached
RobinA3
Well-Known Member
Gold Supporter
Cheshire
Drove the A3 this afternoon and noticed that it wasn't boosting properly, part load is fine but go into WOT and there is a massive drop in performance.
Scanned the ECU and got the following fault code:
16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached
Did a search on the internet for info and got this:
Possible Symptoms
Reduced Power Output
Limp Mode
Possible Causes
Hoses/Pipes incorrect connected, disconnected or leaking
Charger Pressure Control defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check / Clean / Replace Charge Pressure Control
Special Notes
When found in 2.0l TFSI:
Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available under Part # 06F-145-710-G (or newer), see TPI 2016331 for details.
I changed the recir valve 4 years ago when i remapped the car to the type ' B' level which was then the uprated item.
Looks like i will be doing the job again this weekend on the driveway, anyone had this same issue recently?
Issue found, it was the divert valve that was split. Price of the part has gone up from £25 to £45!!!
