Chris NottJMB Retrofits
Results 1 to 8 of 8
    Jun 2008
    790
    Time keeps resetting on A3 clocks...???
    Hi guys,
    Having a small problem with my A3. The time on the clocks sometimes goes dodgy. Not all the time, but at least 3 times now I have had to reset the time. Any ideas what could cause this?
    Looking for the right A4 Quattro. 1.9 TDI / 1.8T or 2.0T...
    My A4:http://www.audi-sport.net/vb/audi-s4-a4-a4-cab-b8-chassis/125399-my-brief.html
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    have you checked for discharge on your battery i may be misinterpreting your post though, what about a vag come check?
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Gee.'s Avatar
    The Dynasty
    Birmingham
    151
    Same happens to mine. Sometimes the clock digits go all random, but when it does actually show properly; I set the right time, and then it resets again when I start the car up.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Weak battery?
    VCDS USER
    Mick a3's Avatar
    Mellow Yellow
    Apr 2009
    Greenock,Scotland
    269
    Most likely to be the battery, Happened with mine and eventually it got to the point the alarm kept going off. Stuck a new battery in it an had no problems since.
    My battery was almost 7 years old.
    sulaiman's Avatar
    Jun 2006
    London
    283
    do you have an after market hid kit fitted? if so move the ballast away from the battery and that will solve the resetting clocks problem.
    A3 TDI Sport
    Jun 2008
    790
    No after-market HID's so that's okay. She has been struggling a little to start recently, and the glow-plugs were changed last year, so shouldn't be that, so I did suspect the battery. Shame, don't really want to shell out on a new one. Just put on a heap of tax, bought new tyres and discs/pads, and I'm wanting to sell the darned thing...
    27,121
    Get the better Varta Ultra Dynamic version from Audi mate, much better than the Varta Blue version that they fit & it only cost me 70 last year where as others were quoting 130.
