Chris NottMonster Motorsport
Thread: Offset on 18s
    Apr 2010
    11
    Offset on 18s
    Hi,
    I am looking to get some 8x18s with 225/40 tyres, the ones I am looking at have an offset of et45, is that offset the best choice considering I am planning on dropping it 30mm after I fit the wheels?
    Model is a 2005 A3 3.2.
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    Yep perfect
    2.0 TDi 140 S-Line With - S3 Vents l S3 Alloy Pedals l S3 Gearknob I Aero Rear Wiper l X-Treme Bulbs l 09 Rear Lights l Custom Floormats l 18" TTS reps l LCR Splitter I Facelift Stereo
    bambam's Avatar
    Sep 2009
    South West
    123
    Yep.
    I have the same alloy specs on mine and its lowered 60mm on Eibach springs...only thing I needed to do was remove the rear arch screw.
    Apr 2010
    11
    Ok, so it has changed slightly, I am now looking at a set with offset of et42, will this also be ok still do you reckon?
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    yep should be fine, only 3mm difference
