AH FabricationsEM Tuning
Results 1 to 11 of 11
Thread: RNS-E coding
    Jan 2009
    118
    RNS-E coding
    Have just installed RNS-E into my car, had to move the BOSE pin but other than that most things are ok (MFSW etc).
    Few issues though:
    - The phone screen says "No phone installed"
    - I don't get the sound settings I was expecting from the BOSE speakers
    - When I press the voice activated button I don't get the RNS-E options
    Is this because I need to tell the RNS-E my car has GSM prep and BOSE? If so are you able to let me know which settings need to be changed? Will I need to goto an Audi garage to do this with VCDS?
    Ibis S3 S-tronic with buckets
    Previously: A3 2.0TDI (170) S-line S-tronic , A3 2.0T DSG S-line, A4 1.8T Quattro Sport
    aristides's Avatar
    Aug 2008
    Greece
    543
    You need to code it man, CAN + MFSW + RNS-e unit need to be coded so you car "understands" the presence of the new HU
    You can either go to your dealer to code it (+ some $$) or find a friend with VCDS and do it for some beer tokens.
    Something i forgot. About the voice recognition system did you wire your BT mic correctly?
    FOR SALE:
    RNS-e 2013 DVD, BK Version, NOT unit, DVD disc
    Steering ECU : 1k0 953 549 AH, ideal for Cruise Control retrofit
    Jan 2009
    118
    Thanks, will try and locate someone with VCDS The only wiring I changed was the Bose pin, did I need to move one for the mic as well?
    aristides's Avatar
    Aug 2008
    Greece
    543
    For your voice recognition to work together with the RNS-e and your BT you need to rewire your mic.
    The current setup leads your mic directly to the BT module. You need to either splice the mic wires and connect them to the RNS-e or create a loop.
    Send the mic to your MIC IN ports (+,-)on the RNS-e and then connect it to your BT module through the MIC OUT ports
    There are plenty of topics around talking about what i just described in case you don`t understand me
    FOR SALE:
    26,777
    Yes rewire your mic to the rns then back out to the BT module, plus install the SDS hack.
    You could always buy vagcom & do all the coding yourself, PM if interested as I sell the genuine cables.
    Jan 2009
    118
    Ah ok thanks a lot, will take a look. The mic seems to work as is at the moment though, guessing once the rns e is coded to know I hava telephone it may cause issues though?
    aristides's Avatar
    Aug 2008
    Greece
    543
    Νο mate, BT will keep working just OK but you will only have voice recognition with the BT and not the whole unit
    FOR SALE:
    Jan 2009
    118
    I see makes sense, where's the BT unit located?
    26,777
    If factory fitted then under passenger seat, under carpet in a plastic housing, no need to touch that at all.
    Jan 2009
    118
    ah so I guess I should be asking, where's the mic located
    aristides's Avatar
    Aug 2008
    Greece
    543
    Inside your map reading lights above your head
    FOR SALE:
