Badger5EM Tuning
Results 1 to 12 of 12
    Jun 2009
    22
    WILL A GOLF ED30 ENGINE AND ECU GO IN AN A3 QUATTRO?
    I would love an S3 8P but the budget is a bit tight at the moment.
    I have an 06 S-line TFSI Quattro donor car and an ED30 Engine available
    The build would cost approx Ł10K for a stage 2+ car.
    The engine, engine ECU and wiring loom from the ED30 are all available.
    Q. Will the Engine and Ecu be compatible?
    Q. Is the clutch compatible? I know the standard cluth on an S3 will only just cope with stage 2+
    Anyone know?
    Jon
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    10k!? sounds a bit mental! surely your car + 10k would equal to a nice S3???
    Gone but not forgotten......
    S
    3 - Phantom Black - Black Optics - Most Extras
    Mods: Revo Stage 2+ - 18" BBS ch/Michelin PS2 - Recaro OEM Buckets - Milltek TBE NonRes/Sports Cat - Evoms Intake - APR hpfp - H&R Springs/ARBS F&R - Sachs Clutch/Luk DMF - AP Racing 6 Pot BBK - 10mm Spacers - Black Rings
    Mods To Do: Full Retrim - MY11 RNSe - Coilovers- Plenty Carbon
    Jun 2009
    22
    I would love an s3 but the budget will only squeeze to an early one.
    There is an A3 TFSI Quattro s-line fully loaded but needs an engine available for Ł7.5K
    The whole 350bhp build would be approx Ł10K total
    I know getting the s3 makes more sense for resale value and less headache.
    This would be a lot cheaper if it is do-able
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    10k total sounds immense value for money. Surely the 2T engine from the S3 is the same from the 2T from the Golf and the A3, just with uprated injectors and fuel pumps . . . ? Much like the 150/180 1.8Ts from 8L A3 can make the same power as the 1.8T 225 S3 with uprated parts. . .
    Just guessing here!
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    i think your right, just internals are stronger i think... but then you have to think about supsension, brakes, clutch, gearbox?? or is all this included??
    S
    KRL
    KRL's Avatar
    Jul 2007
    523
    The ED30 engine is pretty much the same as the S3 apart from the intercooler. The ED30 uses the stock GTI intercooler where as the S3 has an upgraded one.
    Injectors, HPFP, Turbo etc are all the same
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    JD09's Avatar
    Dec 2009
    3,080
    Quote Originally Posted by S3RYE View Post
    And internals, I had forgotten about!
    Good news from below!
    S3RYE's Avatar
    Interior Next!!
    Apr 2009
    London/Essex
    3,456
    ok but have you included for supsension upgrades and brakes??
    im not actually sure how different the tfsi clutch is to the s3 but running 350hp you will need to uprate anyway...
    S
    Mar 2008
    Bradford, WY
    788
    will be lots of work, the s3/ed30 use k04 turbos and standard 200hp 2.0tfsi use k03 turbos. I would personally keep that existing engine, uprate internals and get a GT3071R turbo, its good for 500WHP! you can spend 10K and make a 400BHP 2.0tsfi much easier than doing a whole conversion. Obvisouly you'l need exhaust, intercooler, injectors, intercooler, induction kit etc, but atleast you'l learn in the process.
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    just save and buy the s3 mate if youre speaking on spending that you wont be long and youll be able to walk into a dealers with a brown bag and out with an s3
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    Thats great value for the converison + car! Someone above mentioned that if you spent Ł10k on the 197 bhp 2.0t you could easily get big power ie over 400 BUT that would include new internals as neither engine's rods and pistons can safely cope with 390/400 lb ft torque and over withing bending the rods.
    The Ed 30 only differs from the S3 in having the GTI intercooler otherwise all the time-injectors turbo internals etc.
    The 2.0T clutch is the same as the S3 clutch is is ok for about 330lb ft torque as long you dont abuse it.
    If you can get that engine & car AND conversion for 10k Id GO FOR IT bro! since the car is minus an engine you might as well put the one with the far better turbo and internals in.
    All you'd need after that is the 'little' things ie intake, TBE HPFP,and try get a better intercooler, new software and new clutch after a little while and your laughing mate. Literally.
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,049
    Even if you can do this for 12K then its a no brainer.
    A S3 bashing A3 20TQ for that money is nice. And different.
    Still 4K short of a cheap S3 too.
    Good luck
    Paul
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
