JMB RetrofitsChris Nott
Results 1 to 8 of 8
    Oct 2004
    44
    Fuel Consumption on 3.2Q
    I've been doing a bit of experimentation with fuel consumption since getting my 3.2Q Sline. Heres what i've found.
    All recorded over around 100miles with 80mph ish average speed on a motorway.
    Shell Optimax 30.0mpg
    Texaco Super Unleaded and BP Ultimate Unleaded 27.6mpg
    Stanard 95ron Unleaded 25.4mpg
    Anyone else noticed similar results? is Super Unleaded/BP Ultimate 98ron? Is Shell Optimax 98ron?
    StephaneS's Avatar
    Apr 2004
    Herts
    379
    Re: Fuel Consumption on 3.2Q
    I would say I got a maximum of 2mpg difference, in favor of Optimax, compared with standard 95ron
    however 30mpg is very rare
    only once did I get 33mpg but it was over 80miles of slow motorway traffic at around 50/60mph in 6th.
    average for the last 10 months and 4500 miles I got 24.5mpg that's for a mix between motorway, town and heavy right foot driving([img]/ubbthreads/images/graemlins/angel.gif[/img])
    Oct 2004
    44
    10 months for 4500 miles!?!?? i've had mine 3 weeks now, already on 3000 miles...just cant leave it alone :-)
    imported_xmaslolly76
    It can vary wildley as main garages tend to use a slightly higher ron fuel than supermarket garages as the fuel tends to stand longer and deteriates more normally u end up with around 96/97 ron by the time you pump it so you will get a better performance from a high street garage that has just had its fuel delivery than any were else. Might explain why you would got better performance from shell than any were else.
    [img]/ubbthreads/images/graemlins/smile.gif[/img]
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    Averaged mine at about 26/27 on a motorway run. I wouldnt bother using 95 ron since the performance (and economy) of the engine wouldnt be as good... then again Optimax is darn expensive!
    Oct 2004
    44
    Yer, paying 95p/litre for optimax atm. Well, work is, i'm lucky enough to have an agency card for business + private fuel. Well, that is until my boss sees the fuel bill this month :-)
    nervus's Avatar
    Apr 2004
    1,159
    95 ron is false economy on high performance engines. I definately get better MPG with optimax.
    I noticed the S3 handbook says you can use either whereas the V6 says says 98ron only - i think it would be crazy to run a high performance car on 95 Ron !
    Oct 2004
    Israel
    13
    Lower fuel octane means less resistance to heat and pressure.
    By using a lower octane on advanced cars you actually burn more fuel and get lower performance as the fuel is being ignited prematurely.
