Chris NottMonster Motorsport
Results 1 to 14 of 14
    dgm
    May 2009
    Glasgow
    21
    BEST SHOCKS FOR 2.0FSi SE ON EIBACH PROS
    Per the title, I fitted Eibach Pros to my wife's 2.0FSi SE about 8 months ago with good results. The only downside is the shocks bottom out regularly on poor road surfaces and generally don't cope well with the drop in height. At over 60,000 miles the shocks are a bit tired anyway and I'm pretty sure one of the fronts is on it's way out.
    The question is what are the best replacement shocks to go for with this set up and on a budget of about Ł250 give or take? Would the OEM sport springs be a decent option?
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    I have my Eibach Pros running with Koni FSD shocks which works very well as a combination.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    dgm
    May 2009
    Glasgow
    21
    I would love to go for the FSD's but I'm only looking to spend about Ł250. Has nobody tried the Eibachs with the OEM sport shocks or anything else mid priced?
    PBA3's Avatar
    Don't hate, appreciate!
    May 2010
    Săo Paulo, Brasil
    35
    Paul,
    That is the setup I was thinking of going with. Can you post some pictures of your car? How does it feel on road ondulations/bumps? Does it jump up hard or feels nice, controlled and not too soft (won't hit the plastic liner)?
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    I had Bilstein B4 sport on my last car (bora) with eibach pro kit springs. Was a v good combo, the b4sports are designed to run with -30 mm shocks which I was what the eibachs are. Handled excellent with hardly any roll or pitch and ride was still ok. Not too expensive either,
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    26,777
    Yeap FSD's mate all the way, great combo, well worth the extra dough if you can find it mate trust me as gonna have 2 cars on these soon.
    dgm
    May 2009
    Glasgow
    21
    Thanks for the replies. As much as I'd like to go for the FSD's, I've spent too much improving the looks of this car so I'll have to curtail the spending a bit. The Bilstein B4 sport seems like a good bet and I'll probably give them a go.
    PBA3's Avatar
    May 2010
    Săo Paulo, Brasil
    35
    Pictures of A3's with FSD's + Eibach Pro Kit springs? :D
    Oct 2003
    up north...
    767
    fsd
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,211
    As mentioned Koni FSD's or Eibach Pro dampers.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    dgm
    May 2009
    Glasgow
    21
    Thanks Damian but the FSD's and Eibach are going to cost Ł450-Ł500 and I'm trying to limit it to Ł250 or thereabouts. Any suggestions in that price range?
    Apr 2006
    england
    754
    just going off topic a little, would the h&r 50mm and the FSD'S work as a good combination?
    dgm
    May 2009
    Glasgow
    21
    I've given in to all the advice and gone for the Koni FSD's which I got for a decent price. Still a good bit more than I wanted to spend but if they're as good as you all say then it's worth it. I'll report back once they're fitted.
    dgm
    May 2009
    Glasgow
    21
    Koni FSD's are fitted now in conjunction with Eibach Pro springs and I have to say the ride and handling are transformed. The car was probably on it's original shocks which were well past their best but even so it's just so much more drivable than before. The pot holed, rutted roads are absorbed in a way that was unthinkable prior to the FSD's but the biggest improvement is the inreased confidence you're given in hustling the car along at a decent pace on fast B roads, dual carriageways and motorway. It feels so much more composed and controlled in comparison to the previously easily unsettled ride and allows you push the car further than you would have dared with the original set up. Whilst I appreciate that the 2.0FSi isn't the most inspiring or quickest of engines, it still manages to build up a bit of a head of steam once it's up and running and the Konis and Eibachs allow you to maintain that speed in circumstances where the original set up wouldn't have allowed.
    Whilst this isn't the cheapest of upgrades it's got to be the most effective for cars of this age and model. Anyway that's enough money spent on the wife's car, I'm considering a supercharger for mine in a year or so I'll need to get saving!
