    Apr 2010
    Wolverhampton
    2004 2lt TDi.... 12v socket blown, what fuse is it?
    Hi all,
    Having a bit of a nightmare finding which fuse controls the 12v socket/cigarette lighter?
    I have a 2004 2.0 TDi with the fuse box under the bonnet, in the manual the cigarette lighter is clearly marked in the diagram of the fuse box in the side of the dash, but not for the one under the bonnett??
    Someone suggested F24 which according to my manual is Control unit for CAN data transfer. I tried swapping this with another fuse and the socket still didnt work,
    Maybe I need to replace the sockets, and friend of mine dropped a metal object into it in a fluke accident, there was a small spark and it hasnt worked since. I presumed the fuse had blown but the inside does look a little damaged so maybe it needs changing?
    any help would be much appreciated, thanks!
    V16
    V16's Avatar
    214
    i forget exactly where the fuse is but it's definitely located on side of the dash/drivers side. i just took it to a corner motorshop. had it changed for a 1
    Black A3 S-line 2.0TDi
    Mods: Hybrid Turbo - Custom Exhaust - Weitec Coilovers - Tints - Gloss Black Optics Grill - Led Number Plate Lights - Led Interior Lights - S3 Mirrors - Retro Fitted Arm Rest - 09 rear lights - R8 Oil Cap - Phillips Diamond Vision Lights
    Apr 2010
    Wolverhampton
    sorry my fuse box is def under the bonnet, any idea's anyone?
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    its not all under the bonnet, as above open the doors and pull the side panels
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Jay.Ing's Avatar
    Jun 2008
    Southport
    224
    There are 2 fuse boxes! One under the bonnet and one on the side of the dash drivers side, So your both right!!!
    2012 A3 Ibis White SportBack Black Edition 140
    Mods so far: H&R 50mm, RNS-E, Cruise control, Interior OEM LED mood light, OEM LED number plate lights, OEM LED Puddle lights, OEM LED Footwell Lights, tear drop wiping, Beep confirm on close, pressed plates, HHA & TPMS.
    Mods to come:light/rain sensor (In progress), and so on........
    Gone But Not Forgotten....
    2011 A1 Black Sline 106
    2006 A3 Red Sline 140
    V16
    V16's Avatar
    214
    Quote Originally Posted by RikWolves View Post
