Volks AutosEM Tuning
Results 1 to 8 of 8
    269
    16683 Boost Pressure REgulation Control range not reached
    Right then guys in a bit of a pickle here i am ment to be going away friday morning, here start the process
    Had a limp mode issue abotu 4 weeks ago now read up and thought it may be the MAf sensor so changed that... fine for a day or so then i took it to get diagnosed after i had got it vagcomed and it ended up being a split hose, Car has run fine for about 10-12 days then limp mode again ...
    i have since checked all pipes they are fine had another pipe replace cause i thought that may be it and still limp mode.... it only happens when i am on the motor way or dual carriage way i accelerate up of a round about not harshly just about 3 k revs and bang at between 60-70mph limpmode kicks in ...
    I am just out of my mind with this as i do not know what else it can be ..
    I have the turbo replaced before christmas with a full oil and filter change and done one since then after abotu 1000 miles as recommened by garage....
    also i have had to do a coolant bottle change from when my turbo went and a coolant clean out and change.
    Any help would be appreciated as i have not got the foggiest what it can be now..
    Many thanks
    Kev
    I dont get online a lot so if anyone has had this happen and know how to remedy it ... my email is
    KEvin_lovett@hotmail.co.uk
    07969993696
    Many thanks for your help...
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    try changing the N75 and or Diverter valve
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    269
    i have just looked on google and foudn that a faulty or damaged N75 valve maybe the cause of this becuase it give the symtons i am showing...
    but what is the diverter valve on a diesel?..
    269
    where cani find the N75 valve and also where and how do i do a variable vane actuator clean?...
    269
    hhhmmm yet again same problem...
    working fine for a good month then bam !!!! again..
    replaced the N75 and all vacum hoses going to it....
    anyone else had this problem ?..
    Heard possible veins in turbo wastegate could be buggered?...
    any of this truth ..
    please help.....
    Phatboyruss1's Avatar
    Apr 2010
    Button Moon
    65
    Follow Phatboyruss1 On Twitter Visit Phatboyruss1's Instagram Channel
    I'm having the same trouble.... help!!!
    Jul 2010
    Birmingham
    66
    did you manege to fix this
    Mar 2008
    Bradford, WY
    788
    Check the actuator rod when engine is cold. Most likely its not moving freely as it should. Diesels dont have diverter valve!
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
