AH FabricationsEM Tuning
Results 1 to 16 of 16
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    Strangle idle and drive 2.0tdi 140 BKD
    Hi there,
    car is a 2006 a3 2.0tdi 140bhp BKD
    Vagcom was showing the MAF sensor needed changing so had this changed yesterday, after the MAF sensor was changed the revs went all wierd not so long after the change, also cant really remember if the car was like that before the MAF sensor change but it did cut out once for some odd reason!
    Ive recorded a video to show whats going on! - I dont notice the problem after 2700k revs its mainly between idle and around 2500k during drive as the revs drop back and forth the drive becomes very bumpy as if its a hard gear/clutch change.
    Must also add that the exhaust seems to be loudeer as well!
    car is on 37k miles
    many thanks
    Audi A3 2.0 tdi sport..many mods to follow...just too fussy when it comes to making decisions!
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    I remember tdi-man had this same problem. I sold him a fuel pump back in December which fixed it so you might give him a PM and talk.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    Hi there,
    thanks for the reply!
    hmm fuel pump at 37k miles?! damn.. will PM him in the mean time any more clues? vagcom shows nill deffo not electronic..
    Feb 2007
    1,257
    It`s some time go now so cannot remember to much about it really other then he had a erratic problem with the ideal on his car but no fault codes.
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    thats a bugger! tried contacting tdi-man but with no responce as yet he hasnt been on here recently. I think you may be right, as when i put a bottle of diesel injector cleaner it didnt happen as much.. (or maybe thats all in my head!)
    Is changing the pump a big job? Could the exhaust have anything to do with it? -
    Many thanks
    27,099
    If he means the pump under the rear bench then not too bad, but these are 150, I may have 1 for sale perfectly works, need to know what your version is now before offering, just ring audi & ask them what the fuel pump part no. is under rear bench of your car, then post back, optionally lift rear lower bench & take cover of & see if can see no. on top.
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    ah Nigel! hope all is good buddy. do you think this would sort it?
    Will give tps a bell tomorrow and ask them the part number for the pump
    many thanks
    27,099
    I wouldnt like to say as it would be purely speculative at this moment in time, but it could very well be a fuelling issue mate, its faltering for sure, which on idle could very well point to fuel/air etc from that vid, maf, fuel pumps, injectors, would be things to check, thing is swapping the pump etc you can do yourself so at end of day its either in garage paying hourly plus parts or you do it with a part, your times free as such, garage isnt huh.
    IIRC Mike had some injectors, but rear bench pump is hell of alot easier than that, maf you've done & still present.
    So are there any logs currently to report after maf change?
    Has it had a fuel filter change yet aswell as this may also be a possible.
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    Hi
    hmm very true, the engine management light was on for the MAF sensor now that its been changed and error code cleared drove around for a day with the problem no lights or codes were present.
    The problem wasnt present with the old maf - im 110% sure surely i would of noticed it! *confused*
    Will get the p/n tomorrow. No i dont think its had a filter change recently, its got a k&n air filter.
    many thanks
    27,099
    Have you removed the K&N & just had it open to air, I know its remote but hey anythings possible.
    Feb 2007
    1,257
    Just had a look back on my records and it was the tandem pump tdi-man bought from me. If you have only noticed the problem since fitting the new MAF i would remove the MAF and check it is clean then refit it it plus put some Silicon Dielectric Grease on the MAF terminals. There is a big write up about doing this and making cars run smoother here. http://www.seatcupra.net/forums/show...ghlight=grease
    Feb 2007
    1,257
    I would also remove the K+N filter as those thing give very little actual filtration of the incoming air. The first thing the particles tend to hit is the MAF and damage that. A very good scientific test has proved how bad K+N filters are in the following link. http://forums.tdiclub.com/showthread.php?t=282433
    just017's Avatar
    Apr 2009
    438
    Wow the results on that website seem quite impressive. For 6quid i think i'll order some
    Audi A3 2.0TDi S-Line - Bose - AMD Remap - Pipercross Performance air filter - RNS-e Retrofit - RS4 style Alloys
    rickyquicky's Avatar
    Dec 2008
    London
    340
    If the fuel pump as already suggested doesn't cure it, perhaps look at your EGR valve.
    The EGR valves operation has something to do with the MAF sensor and sometimes faults with the EGR can log as MAF faults.
    EGR's can cause all sorts of problems, crappy idle, smoke, lack of power etc.
    Feb 2007
    1,257
    The EGR also clog up the inlet pipes with soot plus cause lots of other problems. Rip the dam thing off altogether and fit a delete pipe will save a lot of problems.
    tdi-man's Avatar
    Jul 2009
    1,612
    hi
    soz not been on for sum time. mine didn't tick over as bad as that and changing the tandem pump fixed my probelm and i understand that audi have changed the part number 4 times on the pump.
    just lately i changed the radiator and now car ticks over lumpy until warm but the rev neddle does not move up and down stays solid at 850
    i had also changed egr injectors injector loom temp sensor clutch flywheel and still tick over lumpy until i changed the pump...
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
