JMB RetrofitsBadger5
    DOLPHIN DIESEL's Avatar
    Mar 2010
    barnsley
    96
    part number compatability?
    i need a new slip ring to fit my s line steering wheel and have been told by someone on here that the one i need is
    1ko 959 653 d, ive found someone selling a slip ring with the part number 1ko 959 653 c. will this work? the seller says its for a multifunction steering wheel and mine isnt.
    thanks in advance
    drivers side s line fog light wanted for 07 bumper.
    cash waiting
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    presume you are fitting a flat bottom wheel without multifunction?
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Mar 2010
    barnsley
    96
    no just a standard s line wheel, i need to know if it will work asap
    cheers
    cash waiting
    Fossie
    Rhubarb Triangle
    3,969
    The one with suffix 'c' is for a two door car whereas suffix 'd' is a later version for two and four door car.
    It is also useful to know your chassis number and steering ecu number to be certain
    Mar 2010
    barnsley
    96
    where do i find the steering ecu number? also, whats the difference going to be between them?
    cash waiting
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    you find it under the steering wheel, panel off and read it. however if youve vag com you can also check the p/n i belive
    Mods
