Chris NottVolks Autos
    Phil_T's Avatar
    Revo Stage 2+ Audi S3
    Oct 2009
    236
    Ping Type Noise Coming From Front Steering. As Much Help As Poss Please :(
    As above since getting the car back from having the uprated clutch at Statller during low speeds upto 10-15mph the steering seems to make a metal ping noise, I think it is when I go full lock eithier side (Or at least quite far) & the best way to say what it sounds like is a metal ping noise almost like the noise you get when your exhaust is cooling down after a drive or when a metal clip fires off.
    Any help please before it goes for further mods on weds at Statller, As I dont want to fit lowering springs then audi blame it on them
    Revo Stage 2+ - Miltek Non Res Turbo Back Exhaust - Evoms Intake - Autotech Fuel
    Pump - Forge DV - Sachs Clutch - BSH Engine/Gearbox Mounts - BSH PCV Mod - RS4
    FPR Valve - Airlift Performance Struts With Adjustable Top Mounts & Droplinks with Accuair Management - H & R Anti Roll Bars - 42 Draft Designs Shifter Bushes - BBS E28 Magnesium Motorsport Wheels - Piano
    Black Optics Grill & Fogs - Piano Black Door Mirrors - Carbon Fibre Front Splitter & Rear Diffuser
    c_w
    1,061
    Most likely related to a spring or top mount. If the spring turns against the damper/strut it can ping back into position.
    39
    Is the car lowered?
    On my old car when i put coilovers on i forgot to put the bearings in, so it made the same nice when turning.
    Phil_T's Avatar
    Oct 2009
    236
    No it aint lowered, have got the springs waiting to go on but want this sorted first. A guy on another forum suggested wheel bearings. Any other ideas???
    c_w
    1,061
    Wheel bearings generally drone. Pinging usually means something is tensioned then releases, it may just well be that attention on the springs fixes the problem anyway! or at aleast means this aspect is checked (springs seated properly and top mounts correctly fitted/ok).
