Monster MotorsportChris Nott
    gynads's Avatar
    Oct 2009
    338
    FBMFSW question going from a SW to a FBMFSW!
    Will this fit and work ok guys? http://cgi.ebay.co.uk/Audi-TTS-S3-Fl...item3a5b2309ac
    whats gone from a cruise control kit , has turned into cruise plus RNS E, and might aswell fit a FBMFSW!! ive done a bit of research and i think ill be ok with the controller as my ECL light comes on with the ignition? but i have no clue about the slip ring and airbag etc, I have an 07 S3 with just your bogo round generic yawn spec wheel. Your help and input is greatly recieved.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    simply put yes it will, i think you should be ok on the slip ring as for the airbag im not sure on the cutoff between 2stage impact and single stage, are you keeping in mind you could be in for a 300 quid bill for the airbag that goes with that wheel? as for the ecu a part number would be required for confirmation
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    gynads's Avatar
    Oct 2009
    338
    Balls to that then! Hmmmm maybe I'll have to settle for a MFSW?
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    i personally wouldnt bother and try and scoop one for cheap on ebay or from a breakers i cant see me using one, suppose i may settle for just a plain fbsw but ive already got a mf wheel on the s3 and cant see it being used by me too much
    Mods
