AH FabricationsVolks Autos
Results 1 to 15 of 15
    V16
    V16's Avatar
    214
    anyone know if they fit TDI as well??
    i was just wondering if these fit a 2.0tdi engine as well
    http://www.fr-rtuning-shop.co.uk/ind...&productId=404
    if not does anyone know where to buy a good set of intercooler pipes etc, as mine keeps leaking air and the audi pipes are designed crap as the clips aren't that sturdy!
    Black A3 S-line 2.0TDi
    Mods: Hybrid Turbo - Custom Exhaust - Weitec Coilovers - Tints - Gloss Black Optics Grill - Led Number Plate Lights - Led Interior Lights - S3 Mirrors - Retro Fitted Arm Rest - 09 rear lights - R8 Oil Cap - Phillips Diamond Vision Lights
    Oct 2008
    Telford
    2,484
    No 100% sure they wont fit a TDI!
    B6 1.8T Avant s line gmbh
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Forge was talking about making intercooler pipes for diesel A3 cars but no heard anything for ages from them.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Apr 2009
    Malta
    178
    whats the benefit from these ok everybody knows they look better but is that all about it ?
    V16
    V16's Avatar
    214
    ''as mine keeps leaking air and the audi pipes are designed crap as the clips aren't that sturdy!''
    26,716
    You done a pressure test then?
    V16
    V16's Avatar
    214
    cant say i have, but had the intercooler pipe changed cause it had a slit in the pipe! had my car up on the ramp yesterday n again u could feel air leaking which was due to the pipe coming loose this time! im sure theres aftermarket pipes which can withstand more pressure then the original
    26,716
    Could just be age related (although mine are originals on a 54 plate) or its something caught the pipe at some point as they're fairly robust pipes overall IMHO, as I've worked on mine a fair bit & not a sign of any issues as in slits & my cars running higher boost with my hybrid turbo & custom map aswell now.
    I would replace your connecting pipe seals if you can feel air around the joints & also fitment of pipes need checking, make sure the metal U clips have more tension on so the joints cant come apart.
    Although I will say I'm not convinced the joint design is neccessarily the best, but they do seem to work & guess its easier for maintenance reasons as jubilees can be a pita.
    V16
    V16's Avatar
    214
    i'm getting a hybrid turbo fitted on friday, thought it would be best to change the pipes due to more air flow/pressure, but you seem to be fine so maybe there just not sat correctly etc. i'll get them to have a look at it when i get the turbo done.
    26,716
    Yeah as said mate, check & maybe replace the joints seals & re-tension the clips as the pipes have been known to come loose just cause the clips arent either fitted correctly/locked into place or tension isnt enough.
    Once this is done, if you're worried about if there is any air leaks, just do a pressure test from maf area to the IMF pipe, whilst under pressure check all joints for leaks & turbo area, the turbo fitter should be able to do this whilst working on car.
    I actually removed the IMF, EGR & Intake Manifold & cleaned them back to the metal as new, given the crap built up over time especially in the manifold.
    I would also consider a catch can as per Mikey has, to stop any excess oil buildup in the turbo from the rocker cover breather pipe, I noticed since done the turbo, the oil is more noticeable & assuming due to the increased power etc.
    V16
    V16's Avatar
    214
    Thanks mate i'll make sure they have a look at re-tensioning the clips.
    i would like to clean the IMF, EGR and intake manifold as well to clean the crap but i'm no good with the engine components, i'll give it a go next week as i'll have plenty of free time or take it to a local garage.
    oh and how have you found the hybrid turbo compared to stock and with the map?
    26,716
    Quote Originally Posted by V16 View Post
    Clean it yourself mate, just make sure you replace for new gaskets, bolts are reusable, its not rocket science, should be self insanitory how it all connects & goes back mate, take your time & be patient & you'll sort it, dont bother a garage as they'll arse rape you for cleaning that lot out & I went as far as removing all the pipes & the IC, hey if jobs worth doing, do it well huh.
    Yeah certainly alot better, smoother I'd say, an improvement for sure, but gotta sort a catch can asap.
    Summers here so more traction for fwd, yeah baby.
    V16
    V16's Avatar
    214
    yeah true, will have a go next week! should have a lot of time so will just take my time. if i encounter any problems expect a PM lol, but i doubt i should have any.
    Can't wait for the new turbo, have u upgraded ur clutch and brakes or just kept it stock?
    26,716
    Nah mines dsg so no upgrade & I stuck 345mm S3/r32/3.2 brakes on & trust me they're plenty good enough, certainly pulled me up & saved my arse few times, no need for anything more.
    V16
    V16's Avatar
    214
    thats some serious stopping power, not surprised they've saved ur ass!!!lol i'm just gonna have to put some ebc brakes on the moment! should hopefully be able to upgrade the clutch, discs and pads by the end of summer. first time for an rns-e, thats all my interior is missing!
