Chris NottMonster Motorsport
    musclefox's Avatar
    Apr 2010
    12
    A3 Aircon leak help please.., thank you.
    Right i got home yesterday after a 65 mile trip in my A3 2005 2.0 TDI S Line,
    As i parked up with engine still running i switched the Aircon off and got out of the car and could see water leaking at the back of the engine on the floor, i reversed and the water was cold so i assumed it was the Aircon.
    Any ideas anyone?
    Thank you..
    musclefox's Avatar
    Apr 2010
    12
    Just moved this to Aircon section..
    Oct 2009
    111
    Are you sure that it's not just condensation dripping off the aircon unit? That's normal and not indicative of a fault.
    PW-Motorsport's Avatar
    Jun 2006
    Pembrokeshire
    389
    As suggested above, this is the moisture collected by the cooling rad. draining from the airbox.
    Apr 2010
    liverpool
    50
    i thought as above condensation dripping but radiator has a leak had a compression test done and i have broken seam luckily took out a warranty out when bought
    musclefox's Avatar
    Apr 2010
    12
    Thanks guys..
