Monster MotorsportVolks Autos
Results 1 to 8 of 8
    Sep 2007
    171
    VCDS tweak for DRLs?
    Hello all,
    I have a pre-facelift 8P S3... Was wondering how this kind of behavior can be enabled using VCDS / Vagcom:
    http://i74.photobucket.com/albums/i2...7/DSC_0244.jpg
    Using fog lights and/or indicators as DRLs.
    Have had a look around module 09 at the long coding and I can't figure it out.
    Several pages show up in a google search, but nothing that seems to work for an A3/S3.
    Can anyone shed any light?
    Cheers,
    Daniel
    warren_S3's Avatar
    Oct 2007
    6,165
    Wouldn't that be illegal in the UK?
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
    Sep 2007
    171
    Maybe. And also probably in Australia too but I would like to know if it is possible...
    warren_S3's Avatar
    Oct 2007
    6,165
    Is this what you are after?
    FOUND HERE: LINK
    Enable Front Turn Signals (in the lamp assembly) To Also Be Front Parking Lights:
    Follow 'Initial Steps', above, then...
    Click on '09-Central Elect'
    When you go into this module, it will scan for fault codes and go straight to a fault code screen. It should say 'No Fault Codes Found'. Click the 'Done, go back' button to get to the main screen for this module.
    Click on 'Long Coding - 07'
    You may get a pop-up warning, click 'yes' for long coding
    WRITE DOWN your original long code before doing anything else at all.
    Click on 'Long Coding Helper'
    In the Long Coding Helper, set:
    Byte 07 to '5C'
    (Just set the value given for the whole byte, you don't have to flip every bit individually within the byte)
    Click 'Transfer Coding'
    Quit out of the Long Coding Helper
    See that the new Long Code differs from the original one
    Click 'Do it!'
    Verify that the new Long Code is stored.
    Click 'Done, go back'
    Click 'Close controller, Go Back'
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    like said above its entirely possible you could even have it so you can switch em on and off if you bought a new lightswitch
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Sep 2007
    171
    Quote Originally Posted by P5SND View Post
    I have a DRL switch (well on/off spinning dial anyway), it's just that it controls the bulbs next to my bixenons, not the fogs/indicators
    Sep 2007
    171
    Quote Originally Posted by warrencox View Post
    09-Central Elect
    Long Coding
    Byte 07 to '5C' (Just set the value given for the whole byte
    Thanks, this is partially the solution... With this, front indicators both come on and stay on when the main bixenon headlights are on (and on low-beam (or whatever it's called) too)
    Sep 2007
    171
    And just figured out fog lights for DRLs (instead of the proper DRL bulbs next to the bixenons)
    Central Electronics
    Long coding
    Byte 21, bit 0-2
    Change from 05 Bi-Xenon Front Light with separate Daytime Running Lights (DRL) to
    04 Bi-Xenon Front Light without additional High Beam
    This enables the following option:
    Byte 17, bit 4
    Daytime Running Light via Fog Lights
    The only thing I can't figure out now is how to have the front indicators come on with the fogs using the DRL switch... The desired look (more or less) can be achieved with low beam + front fogs (as the indicators now come on with low beam), but I'd prefer the low beam bulbs to be off.
    So does anyone know how to enable indicators / turn signals as DRLs on the A3/S3?
