Chris NottAH Fabrications
Results 1 to 9 of 9
    Karl3's Avatar
    2.0TFSI
    May 2010
    A3 8P Power List
    I'm new on forum, made few searches but didn't found the info I needed. I'm looking for more power modes to engine (sport filter, turbo, chip ...) Now running A3 8P 2.0 TFSI with ABT chip (around 240BHP), but it's quite short on power and I want more. If there is some kind of topic with that list, I will appreciate if you post it. Cheers.
    fattiereturns's Avatar
    A4 2.0T Q
    May 2010
    Aberdeen
    41
    I'm running the A4 with the same engine and am surprised you only get 240 from the chip. I was quoted remap up to 265 but feels like more to be honest... was yours 200 out of the box or 220?
    2007 B7 A4 2.0TFSI S-line SpecEd
    1977 IC1 Dual lung, modified piano keys, built in pub-nav, self-mating
    Karl3's Avatar
    2.0TFSI
    May 2010
    Stock 2.0TFSI gives 200PS/197BHP, ABT Power chip only adds +40BHP
    Checked ABT page, there is more updates for engine, plus will take a look on MTM, still any help would be great.
    P.S. Forgot to say, it is a Audi A3 Q version.
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    You need to change your DV valve, probably make a big difference, the standard ones cant cope with a remap, some even fail on standard cars.
    That & Downpipe /cat & intake and your laffin. literally.
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    Karl3's Avatar
    2.0TFSI
    May 2010
    MTM can provide 310BHP/395Nm, which sound amazing, little suspension, exhaust, brake upgrade and the car will be monster.
    akash_sky1's Avatar
    1,209
    you can only get that much on our engine with a ko4 swap from the s3. in which case it would be the starting point.
    Karl3's Avatar
    2.0TFSI
    May 2010
    Here is the link from MTM.
    akash_sky1's Avatar
    1,209
    Quote Originally Posted by Karl3 View Post
    yes ive seen that before, and if you read it says ' Like 272 HP, but in addition with MTM exhaust manifold, turbocharger and fuel injectors; max torque about 395 Nm; that means new turbo son and like it says manifold to go with it!
    It is possible but not from this engine's current hardware. And that turbo is the S3's KO4 like I mentioned, a long with its injectors.
    AND that would also cost you about 7grand with current x-change rate! Excluding labour lol. Audi are MTMs tuners over here mainly, so not cheap.
    If you wanted to spend that much APR stagr 3 kit is by far the best.
    Karl3's Avatar
    2.0TFSI
    May 2010
    Thanks men, didn't know about APR.
    Will check their web page 4 sure, looks interesting.
    Yeah, APR knows how to make A3 almost fast as R8. Set runs only on 93 and 91Octane, is it the same as 95 and 98E in Europe?
    But still, it's too much, my goal is to set ~ 310 - 330BHP
Tags for this Thread
