Badger5Volks Autos
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    Intake Heat Wrap- About to commence..is it worth covering the fuel lines?
    Hi people, i've ordered some reflective heat wrap AND reflective heat tape on eBay , which can withstand about 450-500 degs of DIRECT heat, used to apply around the engine bay. Im using it to protect my new intake from engine bay heat as its metal and gets pretty warm after a run/idling, heating in the intake air.
    Got the tape first and its adhesive, so putting that on now, just wondering if its also worth covering the fuel lines at front of the engine where the metal is exposed and its not covered by rubber?
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    akash_sky1's Avatar
    1,209
    just put it on and when for a run, the tape was quite warm to touch, but not sure how cool it was underneath. It was abit cooler then the intake would have been normally, but not as much as expected. May need more layers possibly.
    The car did seem a bit better when pullin away again, after idling with a very warm engine. As in better throttle response and slightly less heat soak.
    Got the thick wrap coming soon anyway just for overkill.
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    I would say that you need to log the data with VCDS as you're going by feel, which isn't the most scientific of methods. Upgraded FMIC would be much more effective, but it costs much more.
    akash_sky1's Avatar
    1,209
    Quote Originally Posted by leshkin View Post
    yeah i know but thats for heatsoack in the intercooler which is proably worse,bus as i changed my intake recently i realised this needed doing.
