JMB RetrofitsEM Tuning
    A3 2.0 Tdi Sportback
    Dec 2009
    Manchester
    20
    Turbo Timer.....
    Hello all,
    Recebtly had my A3 remapped taking it up 190 BHP and obviously pushin my turbo to its limits.
    I was just wondering if it would be benificial to fit a Turbo Timier to it just to help it cool down further??
    The only smaine concer i have apart form, is it worth it, is that a couple of VW owners thta have fitted it have had problems with locking the car, as while the timer is running, it wont allow them to lock the car !
    Any help/advice would be great!
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    Would definately prolong the life of the turbo!
    I can't see why it would be a problem, if you can lock the car from the inside whilst the car is on, should be able to do it from outside, unless the car knows the keys are not in the ingition, which it probably will, so it probably won't work, so all of what i'm saying is crap.....
    Sorry
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    I thought on more modern turbos there not really needed as long you let the car coast a bit before tuning off after a run?
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    Dec 2009
    Manchester
    20
    Well i faut the same thing really, as thats wat i do, before i set off and before i turn it off, always have.
    i just wanted a bit of advice but i can see it bein more af a problem creator than anything as i dont really wanna leave my car open and stand vigilante at the window waiting to lock it!
