Chris NottEM Tuning
Thread: Limp mode help
    chris1988brown's Avatar
    middlesbrough
    578
    Limp mode help
    Hi guys
    I recently fit a hybrid turbo but yet to have it maped, I've been using the car and it's been fine even had some sprinted drivin, however yesterday it went in limp mode when cruisin at 70mph I stopes the car restarted n it was fine until I went over 2k revs and keeps doin this, also if sat still wen raisin the revs and letting it off there is a growling sound bit like the turbos gone but checked it and it's fine could this be the egr valve? Any help would be great
    cheers chris
    MY S-LINE 2.0TDI HYBRID PROGRESS
    MY PROGRESS THREAD
    waqi's Avatar
    Apr 2009
    Yorkshire
    150
    Don't quote me on this but I'm pretty sure I read somewhere you'll get limp mode often with a hybrid until you get a new map on - The ecu still thinks it should be producing same power
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    if your hybrids boosting more then what the ECU requests then it'll go into limp mode. Seeing as though your hybrid flows more air the same boost then the original and ECU map is standard this sounds like the cause.
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
