Limp mode help
chris1988brown
middlesbrough
Hi guys
I recently fit a hybrid turbo but yet to have it maped, I've been using the car and it's been fine even had some sprinted drivin, however yesterday it went in limp mode when cruisin at 70mph I stopes the car restarted n it was fine until I went over 2k revs and keeps doin this, also if sat still wen raisin the revs and letting it off there is a growling sound bit like the turbos gone but checked it and it's fine could this be the egr valve? Any help would be great
cheers chris
Don't quote me on this but I'm pretty sure I read somewhere you'll get limp mode often with a hybrid until you get a new map on - The ecu still thinks it should be producing same power
if your hybrids boosting more then what the ECU requests then it'll go into limp mode. Seeing as though your hybrid flows more air the same boost then the original and ECU map is standard this sounds like the cause.
24
805
727
560
