EM TuningMonster Motorsport
Results 1 to 9 of 9
    rickyquicky's Avatar
    Dec 2008
    London
    340
    People who have suffered faulty DMF.....
    - Did the car shake when at idle?
    - Would it stop shaking when you come off the throttle?
    Sep 2007
    171
    No, and no... No shaking, just slip at peak torque that regains grip after slipping for ~500rpm; fine otherwise
    Gryphon001's Avatar
    Jun 2009
    303
    Was it a steady slip or did feel like it was stuttering...?
    Having an issue with mine and waiting till tomorrow to get it scanned at the dealership. Hoping it's just bad coilpacks. I do know mine is dying but not ready to replace it yet.
    Dec 2008
    London
    340
    So how do you diagnose the thing? Surely there is a way to identify a failing DMF!
    I have a DSG box and have NO slipping whatsoever, not sure if a DSG would slip though like a manual.
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Quote Originally Posted by cooni View Post
    That is clutch slip[ nothing to do with a faulty DMF.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Sep 2007
    171
    Quote Originally Posted by devonmikeyboy View Post
    Yet plenty of people have reported identical symptoms and had it rectified with a new DMF.
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    the clutch slips a bit due too the master cylinder rubber bushes sticking!
    Get them changed and flush and refill the hydraulic fluid it will sort out your problem mate.
    When the clutch is changed they will put a new slave cylinder on as a mater of course and also change the fluid so save yourself a fortune and do the very cheap option first then see how you get on?
    Mine has been perfect for the last 12k miles since Audi did this repair for me after similar problems.
    Gaz M
    Black 996 C4S
    B6 S4
    Black S3 Revo 2+ sold
    All options + Miltek TBE, Revo 2+, HPFP, RNS E, Bose, Alpine Ipod interface, TTRS Brakes
    For sale unfitted Forge catch can kit, open to offers?
    also standard S3 factory exhaust?
    Dec 2008
    London
    340
    So what makes you think you have a problem with your flywheel?!
    Just abit of clutch slip sounds like either too much power or a nackered clutch.
    How did you diagnose a faulty flywheel?
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    Guys
    I keep telling you its not a faulty clutch in a lot of case's but a faulty rubber in the master cylinder that cause's this problem!
    The Audi assist guys showed me on my car and said it was a know problem.
    Do the cheap repair 1st before you condem the clutch mine is still going strong after 12k since Audi fixed the sticking master cylinder under warranty.
    Gaz
    Black 996 C4S
    B6 S4
