Volks AutosChris Nott
Results 1 to 15 of 15
Thread: egr blanking
    Ayrshire
    106
    egr blanking
    Anyone blanked off there egr valve?
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Yes thank you.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Mar 2010
    89
    What is the benifit of blanking the EGR what exactly does it do.
    Unforgivable wheel gap
    Mar 2008
    Bradford, WY
    788
    reduces nitrogen oxide emissions. amount of recirc gases depends on engine speed, quantity of injection, amount of air intake, intake air temperature, air pressure. Its pretty important when engine is cold especially diesels.
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    rickyquicky's Avatar
    Dec 2008
    London
    340
    Are there any performance gains by blanking off the EGR?
    Mar 2008
    Bradford, WY
    788
    Quote Originally Posted by r3stu View Post
    yes, exhaust gases are not recirculated back into the engine, so reduces burning efficiency, becuase of less oxygen in exhaust smoke, but when the engine is more than 50ocelcius the egr valuve closes so no exhaust gases go back into engine, so no real point in my opinion. it can be easily switch off with a remap
    Mar 2010
    89
    Is the egr controled by vacum?.
    Feb 2007
    1,257
    The EGR is vaccum controlled and cannot be switched off via a remap but can be switched down via Vagcom.
    @ navnayyar Are you serious that you don`t understand or see the need to remove the EGR on diesel engines or what performance you can get when you yourself drive a highly modded diesel ?
    Feb 2007
    1,257
    Here is the main reason people who are into diesel tuning remove the EGR and have done for years !
    Feb 2009
    40
    I've removed the EGR, it was all gunged up just like the picture above. Once you have covered some miles in the car your EGR valve will look like this too. Eventually it will cease up and you will have to spend money replacing it only for it to gunge up again. You don't have to be a rocket scientist to see why removing this restriction is a good idea. The EGR valve on my car has been replaced with a straight piece of pipe. A quick remap removes the fault light the engine throws. I would never go back and would always remove it on any future cars.
    Dec 2008
    London
    340
    So there are performance gains to be had?
    Or if it stops recirculating exhaust gases when engine temp is 50 degrees then surely theres no point?
    And how can a dirty one make an engine run like crap? Can they get stuck open/closed and then opening/recirculating exhaust gases when its not supposed to etc?
    Feb 2007
    1,257
    There are no performance gains in removing the EGR. What you are doing is stopping the car loosing power because with all that gunk in the pipework it restricts the air flow therefore less power.
    Phatboyruss1's Avatar
    Apr 2010
    Button Moon
    65
    Follow Phatboyruss1 On Twitter Visit Phatboyruss1's Instagram Channel
    Is there a how to to remove and clean the EGR on here somewhere?
    Feb 2007
    1,257
    Here is a quick guide. It`s for a Mk4 jetta but the basic principle is the same.
    http://pics2.tdiclub.com/gwillie/VW/...AKEMAN101b.htm
    Apr 2010
    Button Moon
    65
    Cheers fella
