Chris NottMonster Motorsport
View Poll Results: Your situation
Voters
28. You may not vote on this poll
  • Revo remap with mini misfire + misfire at high rpm
    4 14.29%
    6 21.43%
  • Other remap with mini misfire + misfire at high rpm
    1 3.57%
    3 10.71%
  • No problems
    14 50.00%
Page 2 of 2 FirstFirst 12
Results 41 to 54 of 54
  1. #41
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    yes...and the hesitant acceleration. thought it was the stock fuel pump that was the problem, but after fitting the forge fmic and denso ik24 everything is nice and smooth now. my old spark plugs after 15000km were really wasted.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
  3. #42
    waring192's Avatar
    Dec 2009
    North West
    390
    Cheers, will pop out and get some later today. Will let you know how I get on.
    S3 Sportback - Ibis White
    Factory: Privacy Glass, Cruise Control, Heated Seats, RNS-E, Bluetooth, Bose, Ipod Dock
    Modifications: Revo Stage 2+, Forge CAI, APR HPFP, Milltek TBE - H&R ARB's & Springs - TV Tuner, Reverse Camera
    Wanted: Stock S3 facelift alloys
  4. #43
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    I might try the Denso's on mine and see if it cures the problem, where is the best place to pick a set up from?
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
  5. #44
    Oct 2008
    888
    restriction due to down pipe.
  6. #45
    waring192's Avatar
    Dec 2009
    North West
    390
    Quote Originally Posted by dc240969 View Post
    I have the milltek TBE and still have the problem
  7. #46
    Dec 2010
    9
    hi there ive got a 2010 s3 and just had it chipped with mtm remap and now 4 days after it seems slow sometimes and on boost seems to pop out the exhaust any ideas?
  8. #47
    East Sussex
    617
    I think the 2.0 TFSI engine has a characteristic of a slight hesitation that is very hard to notice unless you look for it, though a remap does make it more apparent, this hesitation has been noted on a few of these cars with this engine, no way to get rid of it so as far as I know.
    The hesitation I have found is when you are just cruising, on the throttle to maintain a speed, and you get the slightest of hesitation every now again. it is very very slight in an unmapped car
  9. #48
    Oct 2003
    up north...
    767
    the 2.0tdi engine also has this slight hesitation on light throttle - at least some do. with standard car its hardly noticable - but becomes more noticable with a remap and much more so with a hybrid turbo - the more power you have the more you notice the glitch.
    couldnt find a fault with the map ( i actually tried about 5 different remaps and its present in all of them, but all were developed form 2 different base codes) so maybe theres a common fault in the audi map that is always accentuated when a map is tweaked.
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
  10. #49
    East Sussex
    617
    Hmm interesting, I am not happy with it, and still in discussion with my Dealer on how to solve it.
  11. #50
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    try changing spark plugs to colder ones. changed mine 3k miles ago and didn't have problem since. before that i couldn't drive my car how bad it was!
  12. #51
    Dec 2010
    9
    had the plugs changed underwarranty at 8k all is good so far!made me grin on the way home,defo not as fast till its warmed up mind!!
  13. #52
    RAPS3's Avatar
    Moo Moo Land
    1,063
    Hi guys - exact same problem that Jam suffered which has now been cured by a day spent down at Revo.
    There is more info here Stage 2+ done - a few issues | m.VAGOC.co.uk
    Revo seemed to have cured his problem by changing the throttle settings on the map.
    Paul R
    S3 Sportback - Sprint, Buckets, Bose, Rain & light, Alu rails, Piano trim, FT Warning, Bluetooth prep
    S3's now sold - roll on the Golf MK1 Project
  14. #53
    Feb 2008
    Johannesburg - South Africa
    81
    I've had the exact same hesitation for around 6 months, ive changed plugs and coils with no luck. Audi have no clue what the problem is. i've had it checked out with all the mods installed as well as with all the mods removed and still no luck.
    09 Ibis White Audi S3| REVO STAGE 2+ | Autotech HPFP | Custom DP | Forge CAI | H&R Springs |
    EX 08 Phantom Black Audi S3 | REVO STAGE 2+ | Autotech HPFP | Custom DP | Forge CAI | Black Optics | Lamin-X
  15. #54
    East Sussex
    617
    whiteunderarm, tbh it is pretty well the same with all the 2.0 TFSI engine had mine since april 2010. Even Audi know of it and have no idea how to solve it
Tags for this Thread
