AH FabricationsBadger5
Results 1 to 10 of 10
    rickyquicky's Avatar
    Dec 2008
    London
    340
    People who have suffered from a faulty dual mass flywheel...
    Can you describe the shaking symptoms?
    - Is it throughout the rev range?
    - Or is it more apparent at certain rpm's?
    Thats all I need to know
    gazsutton's Avatar
    I MISS MY LCR!
    May 2010
    Near Loughborough
    39
    mine seemsto have a shaking when i pull off only in 1st strange seems fine changing through gears and coming down and in reverse. just when pulling off.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    My wides a4 cab does exactly the same. Been offered a discount on a new one from audi but they won't admit it's a common fault
    david_phillips95's Avatar
    Nov 2008
    538
    My clutch start slipping due to my dual mass falling in on itself under load, DMF's are nothing but trouble, i fitted a brand new one when i installed my uprated clutch but i cant see it lasting much longer than the 19k the original one lasted lol
    Davie
    Sep 2007
    171
    Quote Originally Posted by rickyquicky View Post
    Usually more problems as you hit peak torque. (late 2k, up to around 4k rpm).
    It will seem like clutch slip, (revs spike up about 500rpm without corresponding lurch forward) but then it drops back down to where it should be for your road speed/gear.
    Most notable when there is a lot of load on the engine... higher gears at WOT.
    I believe a faulty clutch shouldn't regain grip when it slips (but could be mistaken)
    Aug 2009
    Darvel, scotland
    135
    Rattle when start up and shutdown, feel it through the clutch pedal, mine goes into ayr audi 17th may to get the gearbox out to replace the flywheel, Mines is a 08 with 23k on the clock stage 1
    GIAC pump & race map WITH CONTROLER, VF ITAKE ,AUTOTECH HPFP,MV DOWNPIPE & MILTEK CAT BK,RS4 REG,UPRATED OEM DV, CUSTOM ENGINE COVER, BOOST GAUGE & POD, H&R SPRINGS, OEM BLACK WHEELS, FORGE CATCH TANK AND WASHER BOTTLE ,RNS-E SAT NAV BLUETOOTH,FLAT BOTTOM, BUCKETS,PRE-FACE TAILLIGHTS TINTS
    Dec 2008
    London
    340
    The problem is I have DSG which seems to be making life hard for testing...
    I have a shake between 1500-2500 revs and cant tell whether its a missfire or the DMF.
    Dec 2008
    London
    340
    BUMP!
    Surely someone can give me some more info on faulty flywheels!
    My car is shaking at certain rpm's when accelerating, it always goes when I come off the throttle. Any ideas at all? I thought it was an engine problem, but a loom and an injector later its not any better...the diagnostic machine isnt picking up any faults.
    Could a faulty sensor NOT bring up a fault code? Maybe MAF sensor?
    Its FWD, 2.0 tdi DSG.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Mostly shaking at Idle - my TDI does it and so does the S3
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    On my old 2.0TDI 140, the car seemed to shake from side to side when at a standstill in neutral
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
