AH FabricationsChris Nott
Page 1 of 2 12 LastLast
Results 1 to 40 of 46
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    Installing Bi-XENON OEM on Audi A3 2.0 TDI from 2005
    Hello guys,
    i'm planning to install oem bi-xenon on my 2.0 TDI Audi A3 2005. Till now i've bought the 2 headlights including the xenon bulbs and the electronics units, the command unit - 1T0 907 357, the two leveling sensors and the wires. I will also have to buy the headlight switch. My question is if there is something else that i need to take into consideration before i will put up everything.
    Thank you!
    27,096
    That module shows for the VW Golf & others, I cant guarantee this has any differences between brands, for sure it doesnt show up on the 8P chassis in ETKA that I can see.
    Also what version of central electrics is yours?
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    I don't know what version i have my vin is wauzzz8p35a016162 where do i have to look in etka?
    Thanks!
    27,096
    You will need to login to module 09 & check this.
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    isn't there a way to check it from etka?
    27,096
    Do you have vin lookup, doubtful, so unless you want to take your trim above your footwell of to visually check or ring your dealer & ask, then thats the only other way.
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    what code should it be in order for it to work?
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    YES i have a vin lookup capable ETKA
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    mine is 8P0-907-279- K
    27,096
    Quote Originally Posted by influxsg View Post
    Which version are you using for vin lookup, 7, 7.1 or 7.2 & is it the Tecar version?
    Yes thats fine, Byte 21 sets the headlight type, just have to rewire.
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    Well i'm using ETKA 7.0 with all it's updated , do you think that there is a posibility to make the bi-xenons adjust from the button inside the cabin, like the halogen ones do?
    27,096
    7.0 doesnt include vin lookup without a crack or dealer login info.
    I dont get that comment at all after you said about installing the kit, why on earth would you want to control the lights via the manual dial in dash when the whole point of the sensors, module & headlights is to do it automatically, rather pointless doing the mod if you want manual control.
    Anythings possible in life, you just have to find the way to do it, but if you want auto aswell then no, I wouldnt even bother, uses different motors & headlights.
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    OK, so i'm a bit dissepointed, i've installed today the kit but my central electronics unit is to old, and doesn't have the encoding for bi-xenon. Apparently mine is 8P0-907-279- A, my question is from where can i buy a newer and updated one.
    Thanks!
    27,096
    Huh, but you said last night it was a K????
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    YES, this is wahat ETKA shows me 8P0-907-279- K but when i've connected vag-com and went on central electronics module the big surprise came: 8P0-907-279- A
    27,096
    Enough said lmfao
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    so, what aprt number should i buy this time?
    Khufu's Avatar
    West coast of Scotland
    5,693
    a K revision supports Bi-xenon for sure (its a highline module as opposed to midline you have), the only problem is it is probably not a direct swap for your A revison module. You would to examine the wiring diagrams for both modules & swap some of the wires.
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    would this fit?
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...T#ht_500wt_956
    And i was thinking of swapping my old module with this one: http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_2712wt_939
    Now to clear things out the issue with the actual central electronics is that i have 2 errors on the dash of the car, that signals me that the durect beams left and right are faulty.
    Khufu's Avatar
    5,693
    its the central electic network that will need changed, not the network controller. Its one of these type of things: http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    Not sure about the switch myself - i find all he different options kinda confusing. You would be better looking german ebay, unless your not actually in Romania?
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    Well i'm Romanian and i live in Romania :D
    27,096
    You need to check your vin with a dealer instead of guessing with your etka that seems to be reporting the wrong data about your car & see what parts supersede & maybe take a chance as I have before on eg. gateway module.
    But your central electrics is an A that supersedes to a D which then doesnt go anywhere & is a basic board, so you are either stuck on D which I dont think will help or you take a chance & get an F or K or even P & see if you can fit this, your choice but they're not specifically for your car, but as people very well know alot of parts on my car arent for it either lmfao.
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    NHM: thanks a lot, so what i've understood till now is that i need to change my central electronics unit with an F and if i'm lucky it will work.
    LE: seems that i need more help, do you think that this will fit:
    http://cgi.ebay.de/Bordnetzsteuerger...#ht_500wt_1182
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    Any ideas?
    27,096
    REDIRECT,8P0-907-279-23-B.LBL,8P0-907-279-E ; 23 Byte (Basis)
    REDIRECT,8P0-907-279-23-H.LBL,8P0-907-279-F ; 23 Byte (Highend)
    REDIRECT,8P0-907-279-23-H.LBL,8P0-907-279-H ; 24 Byte (Highend)
    REDIRECT,8P0-907-279-30-B.LBL,8P0-907-279-J ; 30 Byte (Basis)
    REDIRECT,8P0-907-279-30-H.LBL,8P0-907-279-K ; 30 Byte (Highend)
    REDIRECT,8P0-907-279-30-H.LBL,8P0-907-279-L ; 30 Byte (Highend)
    REDIRECT,8P0-907-279-30-H.LBL,8P0-907-279-N ; 30 Byte (Highend)
    REDIRECT,8P0-907-279-30-H.LBL,8P0-907-279-P ; 30 Byte (Highend)
    You need a highend board, I cant guarantee they will plugnpray with your car once coded, may have to move wires, a risk, but isnt life just 1 big risk.
    27,096
    Whose NHM & LE?
  28. #27
    Mar 2009
    120
    And if you install the P, you will be left with a X-mass tree The rest I don't know.. cause NHN won't share
  29. #28
    influxsg's Avatar
    ANdi P.
    Oct 2006
    Bucharest - Romania
    263
    I've uploaded here what i' have managed to do till now. I can have flashes on bi-xenon, i have DRL that are open the entire period when i have the ignition put on, i have normal xenon range and bi-xenon range. This is a movie with what i've managed. My question for Nigel is if i buy this button and i won't change the bornetz it will fit: http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_2712wt_939
    A short clip.
    http://www.filefront.com/16390013/bi-xenon%20setup.mp4
    Also i figured that i can use some resistances in order to trick the ecu to think that on the DRL sockets he has 55W bulbs, i can do that by installing some 50W resistances but then another problem occurs, these kind of resistance generates a lot of heat and really i don't know how to dissipate it fe without using some radiators.
  30. #29
    Khufu's Avatar
    5,693
    Quote Originally Posted by drsilviuro View Post
    I'm not sure he knows why LOL - Audi transfered the coding across and it worked even thought doing it himself to the same coding it didnt work!
  31. #30
    27,096
    Dont be silly, when I know you'll know.
    Quote Originally Posted by Khufu View Post
    Yes I still need to compare codings & adaptions, once done & I find the discrepancy then I will report back but I am atm thinking there's a hidden step to enable certain things on the module, maybe not, but I've enabled some other boxes & the problem hasnt returned, but will play later.
  32. #31
    Mar 2009
    120
    So if I go with the module to the dealer, they can sort it out?
  33. #32
    v1raj's Avatar
    Apr 2009
    279
    Bump...
    influxsg, any updates with this as its something i would be looking to do in the future.
    27,096
    Bump???
    Why do you need to know if he did it or not, its been proven already to be able to install bixenons etc as I've updated several now using certain modules & wiring changes.
  35. #34
    v1raj's Avatar
    Apr 2009
    279
    Bump???
    Hi NHN,
    I am interested to know how the final price for carrying out this update? i.e parts, labour etc..
  36. #35
    27,096
    That has alot of variables & too many to answer overall in 1 reply, if using/buying from dealer than its a 2k parts list with sensors, headlights, maybe more if updating modules already on car, plus maybe a 1-2k labour charge dependent on what they do overall, if buying 2nd user from ebay etc then could be as low as 6-700, but chances of that are low, let alone the labour you would spend on the job.
    I'm basing the above reply on fitting it as it should be as in axle sensors, correct modules for proper coding.
    Great upgrade for sure, but can become expensive, but one I always think its very worthwhile.
  37. #36
    v1raj's Avatar
    Apr 2009
    279
    Thanks for the info NHN, much appreciated.
    You may have seen one of my recent threads:
    http://www.audi-sport.net/vb/showthr...you-guys-think
    Installing xenons would be at the top of my list of mods so doing quite a bit of research into it. I've found these bi-xenon headlights that include the ballasts:
    http://cgi.ebay.de/2X-ORIGI-XENON-BI...item23066f573d
    They'll alone will cost aroung the 530 mark I guess it's a matter of keeping an eye out for bargains...
  38. #37
    27,096
    Quote Originally Posted by v1raj View Post
    That is a bargain, dealer is 1400-1500.
    Also make sure you get the headlights for your country as lhd & rhd are different.
  39. #38
    v1raj's Avatar
    Apr 2009
    279
    Funds are a bit low at the moment as im on the verge of purchasing the A3 in my other thread. May have to sell one or two things to get these.
    Once i have acquired all the parts needed for the job, are you able to recommend anyone to fit/code everything? (From your comment earlier suggesting you have updated a few, i'm guessing you are able to do this??) If so, how much do you charge and how long roughly does the installation take?
    Thanks for all your help.
  40. #39
    27,096
    Yes I can do, where abouts are you.
  41. #40
    v1raj's Avatar
    Apr 2009
    279
    Based in Northampton
