Results 1 to 8 of 8
    Apr 2010
    Audi A3 interior lights question.
    Hi i have an Audi A3 56 Plate, and i want to change my interior lights,
    im looking LED lights, but there are so many opinions out there, unsure which ones are the best to use, the ideal features im looking for LED lights to be White, and the brightness is good/don't lose its brightness and lights that don't break easily
    anyone help?
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    check out jonny c's guide over on vagoc.co.uk
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    gixxer600k4's Avatar
    Feb 2009
    hampshire - UK
    686
    have a look here http://www.ultraleds.co.uk/automotive-bulbs-c-101.html
    you should need the 40-44 mm for front and i think its around 38mm for back ones i have ones like these
    http://www.ultraleds.co.uk/42mm-leds...te-p-1488.html front and rear and they are very good but i want ones to be brighter like these
    http://www.ultraleds.co.uk/42mm-leds...te-p-1461.html
    also, go for the cool white not the warm white if you are looking for the pure white look!
    rs6's, H&R 35mm, lamin-x, vinyl wrapped grill, cupra splitter, black wing mirrors, de-badged, bmc air filter
    Apr 2010
    thanks for the urls
    I'mRonBurgundy?'s Avatar
    Lets make that kitten purr...
    543
    Anyone seeing errors with these in 2008MY cars?
    http://www.ultraleds.co.uk/42mm-fest...ng-p-2190.html
    2008 A3 1.8T FSI S-line Phantom Black, Bose, iPod Dock, Front Centre Armrest, Storage Pack, Aluminium Pedals, H&R Spacers, Eibach Pro's, Ambient Lighting, Pressed plates with Ingolstadt surrounds.
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    Wink
    Quote Originally Posted by T-Bag View Post
    anyone help?
    these are great,(they will fit front) http://cgi.ebay.co.uk/Audi-LED-Numbe...item439e177bcf (do the numberplate ones) but the right size you need is 42mm front and 36mm rear and 36mm for ya number plate you can just get standard festoon led's and use drl 150 ohm 2watt resistors and then you wont get the bulbs dimly lit up even when there off !
    Full leather/19"wheels/cruise/
    Feb 2009
    hampshire - UK
    686
    to get decent light output you will need to go for a pair like the ones you ask as you will need the more LED's i think the 3 LED is the same as a 7 or 8 watt bulb. so the 9 or even 9 LED might be more what your looking for, as someone said, just get whatever bulbs you want and fit some resistors, you will only need about 2.
    http://www.oznium.com/resistors
    Gryphon001's Avatar
    Jun 2009
    303
    Here is one for you if you are looking for downright stupidly bright domelights... sadly they don't have anything for the map lights in the back.
    http://www.oznium.com/led-domelight
    Here is what it looks like in mine.
