AH FabricationsJMB Retrofits
Results 1 to 12 of 12
    johnnysalv's Avatar
    A3
    Mar 2010
    Trefnant North Wales
    30
    Lowering Springs HELP!!!! FITTING!!
    Help want to fit my lowering spring to the rear of my A3 2005 plate. Whats the best way to fit?????
    Do the rear wheels need to come of? Do I need any special tools just for the rears???
    Cheers Johnny
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    Hi Johnny
    Very simple, ideally take the wheels off yes and grab yourself some axel stands
    Jack the car up, stick the stands underneath so that they are holding the chasis up, not the rear axle
    The hubs will drop down and you can take the springs out with a bit of elbow grease
    Then a case of shoving the new springs in place, and you're done
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
    johnnysalv's Avatar
    A3
    Mar 2010
    30
    How many bolts, do I have been told just to remove the bolt for the shock as its the only thing holding the springin that correct or not?
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    Quote Originally Posted by johnnysalv View Post
    Rear spring and rear shock are different bits mate
    Not like the front where the spring goes over the shock
    I'll be back!!!
    bambam's Avatar
    Sep 2009
    South West
    123
    Are there any guides available for changing the front springs?
    mainly the shock/hub interface and any tips that make the whole job easier!!
    TIA
    Stampie's Avatar
    Fareham, Hants.
    105
    Typical! I have just done mine a thought I'd do a pic guide to changing them - Fronts were such a pain in the arse I gave up with the guide!!!
    STampies tips....
    1 = 2 people (pref male with muscles!)
    2 = Spring compressors
    3 = Ring spanner for removing top nut on fronts - Mine needed 21mm
    4 = Spline sockets - need one for the fronts, although I gently persuaded a Torx socket to fit!
    2010 - Monza Silver - A5 3.0tdi Quattro S-Line Special Edition.
    cooltempo's Avatar
    Heavy DERV clatter
    Dec 2009
    Northumberland
    95
    im thinking of doing this too, my neighbour has two gas lifts in his garage and loads of tools, so hopefully be ok?
    just wondering why were the fronts so difficult? just awkward angles?
    2006 A3 Sportback 2.0Tdi Sport... So far - Stage 2 custom map (dyno'd at 185bhp), Pipercross panel filter, centre armrest, Alpine IDA-X305 and Bluetooth, hard wired Garmin Nuvi 1690T
    To Do's - eibach springs, Votex front lip / spoiler, Votex rear spoiler and skirts, led's all round!
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,974
    ive done mine,took out complete hub,disconnected driveshaft,link arm not too bad of a job
    Full leather/19"wheels/cruise/
    NY_Sportback's Avatar
    58
    check this link as the MKV Jetta and GTI use the same suspension design as our cars, I've done the rears in less then an hour and most of that time is jacking the car up and removing the wheels
    http://www.s****monkey.com/vw/jetta/2006/suspension/
    cooltempo's Avatar
    Heavy DERV clatter
    Dec 2009
    Northumberland
    95
    Thanks NY_Sportback can anyone who has done this confirm that this guide would work with the A3?
    Phatboyruss1's Avatar
    Apr 2010
    Button Moon
    67
    Follow Phatboyruss1 On Twitter Visit Phatboyruss1's Instagram Channel
    Just a quick question before I get ordering I've got an A3 Tdi Sport (53) running 235/35/19's wheels and tyres. I want to lower the car (on springs as its my daily driver and I want to retain some sort of comfort, those tyres can be hard!!)
    I was looking at Eibach springs, which is the best option for me the pro or the sportline kit? has anyone had experience/can recommend with other spring makes?
    Cheers in advance.
    gingers3's Avatar
    Oct 2009
    218
    i think H&R s are better i think eibach only lower the front !
    S3 , CUSTOM CODE , NON RES MILLTEK , FORGE DV , 19" BBS CK (ANTHRACITE) , GREEN COTTON FILTER , ECS DOGBONE INSERT + EVERY AUDI OPTION
