Jon_w
I recently changed the brakes all round, both pads and rotors. Now it has greenstuff pads and EBC Blackdash rotors.
I have followed the break-in procedure, and have been driving carefully on them without excessive braking, until all the black coating had worn off. This took a lot longer on the front than the back. Now that they are finally worn in (not fully, but better and all coating has gone) I did the recommended hard breaking with cool down period, which seemed to help a little, but the brakes still aren't right.
The old pads were completely shot front and back, with the rears having a 1 cm wide rust/dust ring and the front had tramlined on the inside. The brakes are now better, but not what they should be.
I found that there was much more dust on the rear wheels than the front, and confirmed that the balance was favouring the rear when driving on a loose surface at the weekend.
I also have had the rear suspension changed 3 months ago, with parts from Audi, but the back is maybe a little lower than before. The car is S-line sports package (seats, suspension, steering wheel etc, but not external bodykit). Are there different levels of lowering with the S-line suspension? Could this be throwing off the tilt-sensor enough to prematurely lock up the back wheels, or could this be the result of air in the front brakes?
I had to bleed the rear brakes to screw-in the piston, but the fronts screwed-in easily with the reservoir closed and the bleed nipple closed also.
Before I take it to a garage to check the balance, is there anything I can do first to check myself? and hopefully correct myself.
Any help would be much appreciated.
By the way, is it correct that there are brake warning cables on one of the front pads, but none on the rear?
