Monster MotorsportEM Tuning
    rickyquicky's Avatar
    Dec 2008
    London
    340
    2.0 tdi injectors/injector loom
    Has anyone had experience of a faulty injector or injector loom on here? Or knows what is more commonly at fault.
    Ive narrowed my misfire down to either of the 2, but now its trial and error, i've bought a new loom to try, and if that doesnt cure it then a new injector.
    Also, anyone know how easy the injectors are too fit? I know its easy to fit, but a mate of mine said to be careful as sometimes they need proper setting up with a computer?
    Mar 2008
    Bradford, WY
    788
    A mate of mine has the same fault on 2.0tdi140 passat. He changed both loom and injector. He says its not fixed the fault! When fitting injectors make sure seals are tight. Now its coming up with jet pump intermittent fault i think? The dealers said its not the fuel pump. Si he's lityle stuck at moment
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    @navnayyar It does sound like the fuel pump mate but strange he wasn`t getting that fault before fitting the injectors and loom.
    @rickyquicky The looms are know to fail sometimes and is usually the best thing to change if there is an injector fault code. Fitting the injectors is fairly easy if you are mechanically minded and know the correct torque rating for the injector bolts etc. There shouldn`t be any need to set up with a computer or re-code with the ECU.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Dec 2008
    London
    340
    Thanks for the replies, to give you a little more detail my mates diag machine was set up to show the fuelling to each cylinder, after we found the error code for 'intermittent misfire cylinder 3'.
    Cylinders 1, 2, and 4 on the fuelling graph showed the fuelling raising and dropping with revs, throttle, etc. Cylinder 3 was pretty much a straight line chucking in loads of fuel all the time. Occasionally it would drop down but most of the time it seems to be just flooding the cylinder.
