AH FabricationsSky Insurance
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,851
    Help with resistors/led's interior
    Im fitting led festoon bulbs in the roof lights in my A3 SPORTBACK
    1st of all am i right in thinking il have to fit resistors,if so are these the right one (330ohm) or do you guys advise me differently ? http://www.maplin.co.uk/Module.aspx?ModuleNo=341602
    Also are front roof festoons 42mm and rear 36mm ?
    Full leather/19"wheels/cruise/
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    Have you checked out TobyCruise's thead from the FAQs? http://www.audi-sport.net/vb/showthread.php?63459-The-A3-S3-LED-Bulb-how-to-Guide!
    He says 150 ohm is the highest you should go. Also 0.6W isn't enough.
    8P2 S3
