Results 1 to 16 of 16
    fuji's Avatar
    Apr 2010
    Colchester, Essex
    23
    TDI 170...To de-DPF or not?
    Looking at getting a remap in the very near future, just wondering whether it would be worthwhile getting a de-DPF, exhaust system fitted before?
    Will i see significant gains with de-DPF/exhaust system over standard system?
    Is it true that remapped 170's have problems with the DPF's after remaps or is that old news?
    Any advice is appreciated,
    Thanks.
    mdre83's Avatar
    Aug 2007
    South East
    629
    Might be worth checking this thread out,,,
    http://www.audi-sport.net/vb/showthr...n-s-170-s-line
    A3 8P2 2.0TDI S-Line 170 SB | Brilliant Red | Full Leather | BOSE | 6 Disc Changer | None Smoking Pack | Light Interior Pack (Converted to LEDs) | Rear Parking Sensors | S3 Air Vents | S3 Mirrors - Stolen!| S3 Pedals |
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    If your going to remap it i would deffinately get the DPF removed as well. The DPF is a badly designed piece of crap that is well known for constantly playing up and no the DPF doesn`t like to be remapped. You will gain an extra 20-30 bhp with the DPF removed and you will not have to piss about doing regen cycles and having the DPF telling you how to drive the car any more.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    mdre83's Avatar
    Aug 2007
    South East
    629
    Deleting the DPF will cause a little smoke out the rear though, but if your gaining 20-30bhp whos cares!
    fuji's Avatar
    Apr 2010
    Colchester, Essex
    23
    Thanks for the responses guys. So you helped to decide on a De-DPF along with a remap.
    Now my next quandry is as follows...
    Shark Performance - DPF-Off (Cut out DPF) and Shark Remap - Ł619 (Increased to 215BHP and 300lb/ft)
    JBS Auto Design - DPF-Off (Replace with Miltek Downpipe) and Custom-Code Remap - Ł735 (Increased to 210-240BHP and 310-340lb/ft)
    I feel that Shark's power claims are a little underwhelming considering AMD can produce 195BHP / 315lb/ft with the DPF.
    Is shark sticking to 300lb/ft to conserve the clutch or is it that JBS figures are somewhat optimistic?
    Will my standard clutch give up fairly rapidly with JBS mid-range claims of 230BHP/330lb/ft?
    Please may i have your opinions as i am stuck between the two options.
    Thanks.
    HIGGINS's Avatar
    Mar 2010
    520
    Thats my results after a REVO remap on my 170 quattro. I was hoping for a little more tbh with around 10 more brake.
    Feb 2007
    1,257
    Quote Originally Posted by fuji View Post
    Thanks.
    300 lb is the quoted max torque of the clutch. If you want more torque Shark claim to be mappers so they should be able to give your car the same torque as what JBS/CC claim. I would be interested to know what Shark actually do with the DPF censors if they just cut out the down pipe and fit a straight bit of pipe or have copied the Miltek enlarged down pipe with places for the censors. Which ever place you go make sure you get a before and after dyno done so you know what power the map is actually making.
    ghouseman's Avatar
    Gazza
    harrogate
    92
    Hi guys, does taking the dpf off make any differance with mot or anything?
    fuji's Avatar
    Apr 2010
    Colchester, Essex
    23
    Quote Originally Posted by devonmikeyboy View Post
    If my understanding is correct, they split the downpipe, hollow out the DPF then weld back together. Thus keeping the appearance of having a DPF, without the filtering aspect, i can only assume all sensors remain in place.
    fuji's Avatar
    Apr 2010
    Colchester, Essex
    23
    Quote Originally Posted by ghouseman View Post
    AFAIK there are no MOT issues without the DPF as the only testing conducted under MOT is a smoke test for Diesels. However removing the DPF is illegal elsewhere in europe.
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Think thats right, I'll get Ben to come along and confirm.
    "Will these wheel fit my car PM's will not be replied to, do you research & use the SEARCH button"
    Detailing - Wheel Refurbishment - Shark Performance Software - VagbremTechnic Dealer - OEM Retrofitting - Remus - V-Maxx - Goodridge
    Indie_DSG's Avatar
    Jun 2009
    99
    I just had my PD170 mapped at AmD :-)
    As its DSG, Shaun could not get a true read from the Dyno but the reading that was gained before the car jumped to 5th was 191Bhp!
    This is with the DPF still in place.
    I could go for a full De-DPF in the future with Miltek and a map change for around Ł850. Think I'll play with what I have for now!
    All I can say is what a difference already!
    Oh yeh, I had a panel filter fitted too.
    Indie DSG
    A3 TDi DSG 170 Bhp S-Line - GOING SOON.....!!!
    A4 TDi DSG 140 Bhp S-Line Wagon - ARRIVING SOON....!!
    S3 DSG Pedal For Sale...
    S3 Rear Valance & Diffuser For Sale...
    Cupra Front Splitter BNIB For Sale...
    PM me for details......
    Sep 2005
    Worksop, Notts
    97
    Yep, that's correct
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,110
    Cheers Ben.
    Feb 2007
    1,257
    Quote Originally Posted by Indie_DSG View Post
    I take it Shaun/AMD don`t know how to dyno a car with a DSG box then ?
    Give him a ring and tell him the next time he puts a car on the dyno with a DSG box to get a correct reading just remove the ESP fuse and do the test in manual mode, (5fth gear in case of the 8 gear multitronic). The test then can be done, Do not touch the kick down.
    Matt's Avatar
    Jul 2006
    Cumbria
    1,416
    Mine has been remapped since December with the DPF still on and had no problems with the DPF.
    Sold: A3 2.0 TDI 170 S-line | Full leather | BOSE | Phantom Black | Bluefin
    Now: Mini John Cooper Works
