Chris NottVolks Autos
Results 1 to 7 of 7
    Wozski's Avatar
    480
    Wheel Nuts/Studs..
    Need some advice on replacing some wheel nuts on my A3. If i go to a breakers yard and ask for some wheel nuts - aslong as they are the same size as the ones im replacing i should be ok irrespective of what car they have come off?
    akash_sky1's Avatar
    Glasgow (Sheffield occas.)
    1,209
    nope. the thread length, pattern and diameter differs, and can have tapered or cone heads.
    A3 2.0TFSI quattro Sportback Lava Grey | | GIAC K03 Extreme Map | Autotech HPFP | RS4 Fuel Regulator | Neuspeed P-Flo | BSH PCV Fix | MV Sport DP | S3 Intake Cam | 285 BHP & 320 lb Ft Torque
    Votex Kit | TD Pro race 1.2 | Schwarze Audi Rings | Alu Rails | Sachs Clutch | H & R Now gone. Current- A5 Cab 2012
    Oct 2008
    Telford
    2,488
    Seems on odd question, whats wrong with the nuts on it?
    I think I have a full set of brand new ones in my shed, i'll have a look
    B6 1.8T Avant s line gmbh
    Wozski's Avatar
    480
    Quote Originally Posted by Lee_R View Post
    The nuts im replacing are locking nuts ( i couldnt get them off over weekend so im replacing them with normal standard nuts)
    Im gonna see if they have identical ones and go from there??
    devonmikeyboy's Avatar
    As far from JBS as possible !
    Feb 2007
    1,257
    Just go on ebay as there are loads of companies that sale cheap locking nuts for your car from 7 delivered upwards.
    06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
    Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
    Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
    Other car 500+ bhp MK4 Golf R32 turbo.
    Wozski's Avatar
    480
    Thats the problem i dont want locking nuts as i nearly couldnt get my last set off.
    Feb 2007
    1,257
    Thats why you should put some copper grease on the thread of the nuts so they don`t rust in. I have several sets of standard nuts laying around if you want some.
