Results 1 to 9 of 9
    Dec 2009
    166
    Talking Need help with retrofitting bixenons
    Hi i've recently retrofitted the ecode for my 07 a3. The headlights work but i don't know how to make the DRL work. Since i got the car with halogen lights my original switch does not have the DRL. However i bought the TT chrome headlight switch and has the DRL but no plugs for it.
    Anyone know how i can make this work? probably a part # for the harness that goes in there?
    The 2 small wires aren't plugged in, only the headlight wires are in place. since the small wire plugs are already in use.
    this was the diy i followed
    http://forums.vwvortex.com/zerothread?id=4130739
    and this was my other question
    http://forums.vwvortex.com/zerothread?id=4853270
    Thank you so much!
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    you may have to run wires parallel with the loom ill check it out tonight after i finish provided you havent gotten an answer by then
    Dec 2009
    166
    thank you sir! i've also PMed NHN!
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    yep im sure he will get round to it before me im not home till around 10 tonight
    Dec 2009
    166
    any luck sir?
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,137
    NHN and mattandrew of the gurus of this!
    27,099
    What is the module version in vcds module 09 for a start?
    You need to wire the drl's in anyway aswell as coding if possible or they wont work properly.
    Ideally the central electrics board needs to be a 23byte version F upwards to be able to code the headlights properly.
    You will need to also make up the wiring for the headlight switch missing plugs with connectors from audi & repair wires, also you'll need elsawin to know where to wire everything, have you got vcds & elsawin?
    What is the headlight switch part number out of interest, assume its the seperate dial drl switch, does it have the ch/lh button aswell, which would be the E versiion headlight switch?
    Dec 2009
    166
    for the DRL wires, something else is already in use in the plug that hooks up into the ECM. So should i try swapping the wires out? or tap it? I don't have a elsawin but i do have a vagcom i can borrow it from a friend.
    As for a switch this is what i'm currently using
    http://oemplus.com/index.php?main_pa...roducts_id=405
    Originally my car came with no tech pakg, or anything just halogen lights.
    The bixenons work fine with now with the coding i had to change from the DIY
    this retrofitting DRL seems alot of work!!!
    thank you for your help!
    27,099
    Get hold of elsawin just to verify/check what the existing wires are for mate.
