Badger5JMB Retrofits
Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 139
Like Tree2Likes
Thread: Facelift mirrors fitted.....
  1. #81
    27,105
    Quote Originally Posted by sub39h View Post
    one member on here did a full facelift front end. he plugged his mirrors into his old door modules and they've worked completely fine for him.
    Depends on what you call completely as the led part will only work with the correct door modules, however everything else wiring wise uses the same connections, I seem to recall this conversation before & it turned out it wasnt as per oem or something like that.
  3. #82
    May 2010
    2,502
    hmm that wasn't the impression i got from this particular member. i've got facelift door mirrors anyway. but considering the plugs are the same there's no harm in giving it a try - i would do exactly that but my wing mirrors are 130mi away at my parents' house. when i get back to leeds next i'll give it a go
    2006 Phantom Black A3 2.0T S-Line.
    DSG | 18" BBS Pescaras | Rear Parking Sensors | MFSW | Symphony II | BOSE | Auto lights/wipers | Half leather
    MODS : '09 tail lights | TT vents | Weitec Hicon GTs | RNS-E 2010 | Controls Pack (Red Stitching)
    PLANS: Dumbos | 8P3 S-Line Rear Bumper | OEM Parking Sensors
    GONE BUT NOT FORGOTTEN:
    2005 Ebony Black A3 1.6 Sport tiptronic. You will be missed!
    1997 BMW 316i Coupe M-Sport. You won't be missed quite so much!
  4. #83
    27,105
    J modules were added in 08 & were fitted on a phased in facelift as we're aware, these were the 1st to feature facelift led indicators, so unless you have J or above, then led's will not work oem fitted, as there isnt coding for it, bottom line.
  5. #84
    tdi-man's Avatar
    Jul 2009
    1,612
    i thought the led wires just had to be pluged into ceb
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
  6. #85
    tdi-man's Avatar
    Jul 2009
    1,612
    led wiring
    Quote Originally Posted by scottie123 View Post
    There are two ways to get them fella.
    First is fit new door modules and iirc some rewire is needed
    second way is to tap into the original Side repeaters on the ceb
    Mechanical fitment is a straight swap as long as you get the correct ones for you car (3 or 5 door)
    They can be made to fit vise versa, but is a lot easier with the right ones.
  7. #86
    27,105
    No, oem is to wire into door modules & code them, the other route is a shortcut & tbh not one I advise as you never know the issues it may raise later, adding to a circuit its not meant for, it may or may not be ok, but I wouldnt want to risk a 200+ CE on that bet.
  8. #87
    Apr 2011
    197
    I have two brand new door control units osf and nsf p/n 8P0 959 802J and 8P0 959 801J
    The reason I have them spare because of a none showing retro fit job for folding mirrors.I have since fitted the Mirrors to another vehicle but have these spare
    So if anyone is interested give me a shout with a figure
  9. #88
    tdi-man's Avatar
    Jul 2009
    1,612
    hi
    im just after the second way is to tap into the original Side repeaters on the ceb for know to test them and make sure the leds work and im happy with the mirrors.
    A8 can u in box me what sort of cash you want for them ?
  10. #89
    scottie123's Avatar
    Oct 2008
    1,888
    I wired into my ceb due to the main reason of cost at the time
    Doing it that way was only a temp fix until I got hold of correct doors modules.
    I do now have a set , but I still haven't fitted them yet. It's on the list :-)
    Nhn is totally right in what he is saying. I know mine have been in a year, and tbh , they have been fine up to now, but somethings hide for a while before rearing there ugly head!
    My advice would be to fit new door modules, as it is a lot easier and totally oem.
    However, if you decide to hard wire straight to ceb, it is very easy to find the correct 2 pins with a test
    Meter. Just look for switching voltage when indicator is turned on
    05 SB SE BKD
    Build Thread
  11. #90
    tdi-man's Avatar
    Jul 2009
    1,612
    any chance some one could just say which pins i need to use as not got a test meter and like i say it is on to test them ?
  12. #91
    scottie123's Avatar
    Oct 2008
    1,888
    Pin locations for ceb are shown here fella
    Ceb
    Can't remember the pins of the top of my head fella, it was well over a year ago !!!!!
    05 SB SE BKD
    Build Thread
  13. #92
    tdi-man's Avatar
    Jul 2009
    1,612
    Ok thanks I take it wiring it that way won't bring a fault light if the dis
  14. #93
    scottie123's Avatar
    Oct 2008
    1,888
    I have had to leave my 501s connected from original side repeaters to stop bulb out errors
    05 SB SE BKD
    Build Thread
  15. #94
    May 2010
    2,502
    mine are K from an '09 so they should be ok lol. tbh i've been thinking of selling the whole lot anyway. it'll make me want to do the front end which i have neither the time nor the money to do!
  16. #95
    tdi-man's Avatar
    Jul 2009
    1,612
    ok thanks so i take it 1 wire from left door mirror goes to pin 11 and right door is pin 6 or 10 ?
  17. #96
    scottie123's Avatar
    Oct 2008
    1,888
    Quote Originally Posted by tdi-man View Post
    it depends on how many pins your plug has . either 11 pins or 12. count how many pins your plug has then use the info for the chart
    Turn signal right
    + means +v is output from ceb
    VESCM 11 pin plug ,pin 06:12 pin plug, pin 10
    So if your plug has 11 pins it will go on pin 6 , and if you have a 12 pin plug, it will go on pin 10
    05 SB SE BKD
    Build Thread
  18. #97
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    Would a "K" Door module be ok for this mod ? And is it a stright swap no wiring ?
  19. #98
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Can anybody shed some light on this ?
  20. #99
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    no m and up
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
  21. #100
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Quote Originally Posted by P5SND View Post
    no m and up
    Then why does NHN Say J or above ?
  22. #101
    Kelza's Avatar
    MODERATOR
    Oct 2010
    Cumbria
    2,551
    hi there does any one have the part numbers for the audi mirror auto folding mechanical led motors... ?? cheers
  23. #102
    27,105
    K supersedes to a J which supersedes to an M, take from that what you will.
  24. #103
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Thanks......So would it be just a plug in and play thing ?
  25. #104
    27,105
    No, for 2 reasons, 1st if its a facelift or prefacelift you do need to code for your cars features although if wired correctly your car may work of the bat fine & if its prefacelift then the looms 32 pin/20 pin need repinning to work.
  26. #105
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Would it matter if I bought the door module from Germany ? as there cars are left hand drive ?
  27. #106
    Apr 2011
    197
    i have two door control units
  28. #107
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Quote Originally Posted by a8 tech View Post
    What Modules do you have ? PM Me price please.....
  29. #108
    Apr 2011
    197
    There for a 2008 S3 osf and nsf p/n 8P0 959 802J and 8P0 959 801J £100 for the pair
  30. #109
    Apr 2011
    197
    Smile
    now on ebay
    2008 8P AUDI A3 DOOR CONTROL UNITS FOLDING MIRROR FUNCT | eBay UK
    SOLD.............................................. .................................................. .......
  31. #110
    Apr 2011
    197
    For Digzz
    pin outs 2004 and 2008 onwards
    Connectors, door control unit, driver side -J386
    20-pin connector (supply, lock)
    1 - Mirror dip input signal 1 (EC mirror +)
    2 - CL motor SAFE
    3 - CL feedback locked/safe
    4 - CL outside door handle
    5- Vacant
    6- Vacant
    7 - CL terminal 31
    8 - CAN - High
    9 - CAN - Low
    10 - Mirror dip input signal 2 (EC mirror -)
    11 - CL motor SAFE/lock
    12 - CL terminal 30
    13 - CL keyswitch close/open
    14- Vacant
    15 - CL door contact switch
    16 - CL motor unlock
    17- Vacant
    18 - WL enable, terminal 87 (vacant)
    19 - WL terminal 31
    20 - WL terminal 30
    16-pin connector (exterior mirrors)
    1 - Mirror status position X (only with seat memory fitted)
    2 - Mirror terminal 31, potentiometer (only with seat memory fitted)
    3 - Mirror supply, potentiometer (only with seat memory fitted)
    4 - Mirror adjustment motor Y-direction
    5 - Mirror adjustment motor X/Y-direction
    6- Vacant
    7 - Mirror heating
    8 - Mirror dip output signal 1 (EC mirror +)
    9 - Mirror status position Y (only with seat memory fitted)
    10- Vacant
    11 - Mirror terminal 31
    12 - Mirror adjustment motor X-direction
    13- Vacant
    14 - Mirror folding motor -
    15 - Mirror folding motor +
    16 - Mirror dip output signal 2 (EC mirror -)
    32-pin connector (to door trim)
    1 - BE - Exit/warning lamp
    2 - BE - Terminal 31 (2) (AWL)
    3 - BF - Window lifter button rear right
    4 - BE - Terminal 31 (1) (AWL)
    5 - CL SAFE LED
    6 - BE - Terminal 58b (1)
    7 - BF - Interior locking button (LOCK/UNLOCK)
    8 - BF - Window lifter button front right (local)
    9- Vacant
    10 - Memory button + emergency off button (only with seat memory fitted)
    11 - Memory position buttons (only with seat memory fitted)
    12 - BF - Tailgate remote release button (only in 5-door, USA)
    13 - Alarm system Off button (tilt sensor inactive)
    14 - BE - Interior door handle illumination
    15- Vacant
    16 - Status LED button for interior monitoring (deactivate interior monitoring)
    17 - Status LED button for alarm system off (deactivate tilt sensor)
    18 - CL - Inside door handle (not implemented)
    19 - BF - Mirror adjustment L/R
    20 - BF - Mirror adjustment X/Y
    21 - BF - Window lifter button rear right (local)
    22 - BE - Terminal 58b (2) (mirror adjuster switch)
    23 - BE - Terminal 58b (3) (mirror/stowage illumination)
    24 - BF - Window lifter button front left (local)
    25- Vacant
    26 - BF - Child lock
    27 - Memory supply terminal 30
    28 - BF - Button for tank lid unlock
    29 - BF - Mirror heating
    30 - Button for interior monitoring
    31 - LED - Interior locking button (LOCK)
    32 - LED - Child lock button
    (from model year '08)
    2 - CL motor SAFE
    4 - Not used
    5 - Not used
    6 - CL terminal 31
    7 - CL door contact switch
    8 - CAN High
    9 - CAN Low
    11 - CL SAFE LED
    12 - CL motor SAFE/lock
    13 - CL motor unlock
    14 - Not used
    15 - LIN
    16 - CL keyswitch open/close
    17 - Not used
    18 - CL terminal 30
    19 - WL terminal 31
    20 - WL terminal 30
    1 - Not used
    2 - Not used
    3 - Not used
    6 - Not used
    7 - Mirror heating
    9 - Not used
    10 - Not used
    13 - Mirror indicator (rate action)
    1 - Status LED - Interior locking button
    2 - Not used
    3 - Status LED - Child lock button
    4 - Status LED button for interior monitoring (deactivate interior monitoring)
    5 - Status LED button for alarm system off (deactivate tilt sensor)
    6 - BF - Mirror adjustment L/R
    7 - BF - Window lifter button rear right, driver
    8 - BF - Mirror adjustment X/Y
    9 - Not used
    10 - Alarm system Off button (tilt sensor inactive)
    11 - Not used
    12 - Not used
    13 - BF - Button for tank lid unlock
    14 - BF - Child lock button
    15 - BF - Window lifter button front right, driver
    16 - Not used
    17 - BE - Interior door handle illumination
    18 - BE - Door exit/warning lamp
    19 - BE - terminal 31
    20 - Not used
    21 - BF - terminal 31
    22 - Not used
    23 - BF - Window lifter button rear left, driver
    24 - BE - terminal 58b
    25 - BE - terminal 58b
    26 - BE - Switch/stowage compartment illumination
    27 - Button for interior monitoring
    28 - Not used
    29 - Not used
    30 - BF - Tailgate remote release button (only in 5-door, USA)
    31 - BF - Window lifter button front left, driver
    32 - BF - Interior locking button (LOCK/UNLOCK)
  32. #111
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Ok.... Me and RS Need to put the Icing on the cake of are 8p3 conversions.....
    We need to wire up the New mirror indicates ...as it's really frustrating both of us at the moment.....and also dangerous while driving around with no side indicates.
    I've also bought some new alpine speakers to fit in as well......as I'm already getting the door cards off so might as well do 2 things at the same time.....less bother...really...
    I'm ready to fit these new door modules and was wondering what I need to re-pin from my old module?
    My door modules are J .
    Also would I need to take my old indicator wire and put it through 2 of the pin sets ? As I still have my old indicator hanging out from inside the wing.
  33. #112
    Apr 2011
    197
    Just transfer the wing side repeater wires to the door control unit
  34. #113
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Which connector would I put it into ? 20,16,32
  35. #114
    Apr 2011
    197
    t16
    earth 11
    signal 13
    just connect them from the motor to the mirror and test them, if they work just insulate the wing wiring
    see what happens
    if they don't then just wire direct to the mirrors as i need to check the wiring differences 2004 /2009
    2004 j519 sorts the signal out and 2009 i think its a canbus signal
    2009 has a different set up with central electrics and convenience in the same control unit so think you are going to have to wire direct
    see how you get on
  36. #115
    27,105
    Just check the resistance isnt gonna be an issue, if using sides for supply to mirrors, given its going from filament to led's.
    Its always been a can signal for the mirror led's mate, they used the older module still on the 08 facelifts iirc then swapped to the newer module 09 all in one module on MY10, but still retained same can signal for the mirrors through the door modules.
  37. #116
    Apr 2011
    197
    with them having the (k) j519 then yes they should be able to encode the door control units and j519 to send can data to the door mirror
    but it needs looking into as the wiring on the vehicle is 2004 with hard-wired wing indicators
    sure we will find out soon enough lol
  38. #117
    27,105
    I hazard a guess if you used newer door modules that support coding for mirror indicators, it may still work with older CE's as didnt code anything on the CE to support the mirror led's, only coded door modules, but still have to rewire the door modules regardless.
  39. #118
    Apr 2011
    197
    The distributed function would suggest so as indicator switch on signal through steering control unit onto the bus network j519 then forwards the signal to the door control unit and then to the led
    However the can data signal would need binary so I can only presume j519 needs looking at as the 2004 would suggest j519 would simply enable the relay within to out put the signal were as can is generating a command to the door control unit assigned to the network
    Anyway if they wire in of t16 to the led and output test the door control unit it should work
    However then it needs to be checked the input into the door control unit is sending indicator request
    All good fun lol
    Sent from my iPhone using
    My fat fingers
  40. #119
    Digzz's Avatar
    Jan 2009
    London
    1,383
    Ok I'm getting a little confused on what I actually have to do here ... Sorry if I sound a bit of a novice ...
    OK I've sourced terminal 16 and have sourced the wires for 11 & 13 which my old wires need to be connected too.
    So do I disconnect them out of the pin plug and join them to my old indicator wire ? If so what was the point of me changing the Module ?
  41. #120
    Apr 2011
    197
    there is no pin 13 is there in t16 for 2004 a3
