EM TuningMonster Motorsport
Thread: TT wishbones
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    TT wishbones
    I belive a while back people were fitting these to the front of s3's am i right?
    what is involved in it, ie what are the benifits and is the fit a direct swap, also if anyone has wishbones from thier s3 please speak up i may be interested in them
    cheers guys
    Phil
    Jun 2007
    240
    I thought this was more for A3's.
    I believe the S3 already has aluminium front wishbones and subframe whereas the A3 has steel - hence why the TT wishbones are an upgrade for A3.
    ____________
    Sprint Blue S3
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    i think they had camber adjustment as well im on the scrounge as one of mine needs replaced
    Oct 2003
    up north...
    767
    its the tt fwd bottom arms - not because they are alloy (although every little helps, as a certain supermarket says) but because they give a lot more negative camber with some adjustment.
    i dont know if the s3 has the same adjustable and longer arms as the tt though
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    cheers mate, i just got another s3 alloy one
