    S3Sport_Guy's Avatar
    Dec 2009
    55
    Power Steering and Steering Lock
    Hi all,
    Is there any way of changing:
    • Power steering server to make steering lighter?
    • Adjusting the steering wheel lock so that it takes less turns to achieve wheel lock?
    Many thanks
    scottie123's Avatar
    Oct 2008
    1,888
    I believe it is possible to change the lightness of the steering, but I dont think it is possible on yours as you have a s3 sb. It can only be done to older 8ps I believe.
    Why would you want to change your steering so it takes less turns to achieve full lock. Surely that would be dangerous at speed, as it would be twitchy as fook?
    Unless you mean the steering lock as in have to insert keys to unlock wheel fandango?
    Dec 2009
    55
    Cheers - im not talking about adjusting the steering lock massively - just noticed on the Audi that it takes more to turns on the steering wheel to turn the wheels compared to my old car - I like the 10 to 2 hand position on the wheel when going around tight corners at speed - cant do it on some corners i know well in the S3:-)
