Badger5Sky Insurance
Results 1 to 31 of 31
    L33TAY's Avatar
    Jul 2006
    Cheshire
    344
    Turbo Gone!!!! Just out of Warranty.
    Following on from my last post regarding loss of power, the car has been on the Audi computer today and they have informed me that the turbo is knackered, the computer says its 'Over Boosting' so a new one is required!
    First question is, can this be repaired, or is there anywhere that I can pick a second hand/recon turbo up from.
    Second, how much of a job id it to fit?
    Third, does anyone on this forum know of a mechanic that can do this as a job for me?
    Any help appreciated.
    Phantom Black S3, DSG, Buckets, Satnav, Bose, Bluetooth Prep, Heated Seats, Interior Light pack, Highbeam Assist, parking sensors. Done: Lowered H&R Springs, Spacers, Full Miltek Turbo Back, HPFP - Next on list: Evoms, Forge Re-circ Valve, REVO Stage 2+ and REVO DSG Software when available! - Then, no doubt Uprated brakes will be needed, (Better get saving)
    paddy's Avatar
    Audi=No fault code, no idea
    Feb 2008
    Surrey
    5,135
    what car ?
    Jamiekip's Avatar
    Jan 2009
    710
    If it's just out of warranty I'd make a scene with your dealer and ask them to sort out - they do have a bit of flexibility!
    Have you another one on order (looking at your sig?) If so they should really take pity on you and do the right thing by the customer!
    paddy's Avatar
    Feb 2008
    Surrey
    5,135
    Audi + take pity ??
    ask them why Kia are happy to guarantee their cars for 7 years and Audi only 3 years
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    L33TAY READ THIS FIRST MATE!
    Hi mate if the Turbo can produce excess pressure causing overboost then I would suggest it is in pretty good condition!!!
    If the Turbo itself was knackered it would be under boosting mate.
    Possible causes of your problem.
    1, sticking waste gate on the turbo housing (not very likely)
    2, faulty overboost sensor (pretty likely)
    3, faulty knock sensor ( not very likely)
    4, faulty DV valve ( stuck closed)
    5, loose turbo pipes from the turbo to the intercooler (very likely if you can hear the turbo whistle)
    6, faulty vacum pipes on any or all parts of the above list (very likely if you can hear the turbo whistle)
    7, low fuel pressure or rubbish fuel being used or clogged fuel filter ( knock sensor active)
    The car protects the engine from over boost in a few ways, it will cut ignition advance and fuel pressure if the overboost sensor says boost is too high or the knock sensor activates.
    If you cut any of these the turbo will slow down as the engine will not rev!
    If you could hear the turbo whistle before the problem or now then most likly a vacum pipe is split or popped off its location so what ever it was controlling is missing from the system possibly the DV valve or over boost sensor.
    Not sure if there is a pressure diaphram on these turbos as DV valve may do the same job? but if either one was stuck it would allow boost to rise without letting the system bypass the pressure build up!
    If you can overboost then the Turbo is good but some thing in the turbo safety sytem is faulty and the car is just protecting your engine.
    I would recomend you go to a good independent garage mate but not sure who is around you? check out local garages for Turbo specialists or independent Audi if any body knows any around you.
    did you just fill up the car before the problem started ? ( crap fuel or water ? ) this will retard the engine due to the Knock sensor
    I would suggest only use Shell, Esso or BP 97 ron ( fuel is my job mate )
    Look up Keith Edwards racing in Ulverston online and give them a call they are a bit far from you but very helpful so may give you a lot more advice.
    Hope some of this will help you mate. Gaz
    Black 996 C4S
    B6 S4
    Black S3 Revo 2+ sold
    All options + Miltek TBE, Revo 2+, HPFP, RNS E, Bose, Alpine Ipod interface, TTRS Brakes
    For sale unfitted Forge catch can kit, open to offers?
    also standard S3 factory exhaust?
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    Oops
    Sorry guys I didnt realise the last post was so long! Just garages really WIND ME UP! Most just have no clue how somethings work but charge a fortune for the privalge of ripping you off!
    Gaz
    Black 996 C4S
    B6 S4
    Jun 2009
    173
    One of our A3's had a problem with the boost. Cost me around 500 to get the whole job done. Had to replace the existing boost pipe & repaired a fault in the turbo. Can be expensive but if you find a refurbed one you'll be looking around 350-400.
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    when did the warranty finish? - you can sometimes persuade them pay out for a percentage of the cost.
    Audi A3 2.0 tdi sport..many mods to follow...just too fussy when it comes to making decisions!
    warren_S5's Avatar
    Oct 2007
    7,163
    Very much agree with Gaz M's post. SEAT tried to charge me for a turbo a few years back, an it turned out to be a split hose when it was checked by an independent. They had quoted me 2,400 and it ended up costing me 40.
    Audi S5 3.0V6T Coupe Black Edition
    L33TAY's Avatar
    Jul 2006
    Cheshire
    344
    Thanks for the reply guys, and thanks Gaz m for the detailed post, think maybe the best option is try to get Audi to do something free of charge as it is could be anything.
    Yes Have just ordered a car from them too, but they are not forthcoming, pity can't get the deposit back off them and go somewhere else! Thats the thanks you get for spending 32K
    Sarah's A3's Avatar
    MODERATOR V6 S3 Hybrid
    Cheshire to Perth AU
    5,923
    If it helps, when my turbo went mine was about 6 months out of warranty. After loads of haggling and emails to the top guy! we got 500 off the bill. Sadly for us we had to go with them cos my car was in bits with them and they wanted to charge 300 to put back together if I wanted to take it elsewhere!!! They should be alot mmore helpful, sadly they aint! Mine made a whining noise that got sooo loud, turned out to be the bearings had gone.
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    I agree with warrens post
    This could be a very cheap fix if you have an independent check the car out.
    I would suggest the turbo is not quite at fault here but one of the safety features or a hose mate push Audi to prove the turbo fault to you if you still go that way and let us know more info?
    Gaz
    Black 996 C4S
    B6 S4
    Jamiekip's Avatar
    Jan 2009
    710
    Or a polite email to the head honcho jeremy hicks...
    You spent 30k on an S3, you've ordered another 30k S3... yet just outside warranty the current car has developed a serious problem...
    ... now in my experience there are situations where it pays to keep a customer on side by doing the right thing... and a simple call from him to your dealer saying they will honour the warranty will solve all your problems....
    Worth a shot and I know intervention from this guys has helped many others :D
    L33TAY's Avatar
    Jul 2006
    Cheshire
    344
    I'll try the above, however, really need my deposit back now as will no doubt need to spend 1K + on my current 2.0 TDI, so is there a cooling off period of say 7 days for the return of a deposit/change of mind etc?? As only paid it Thursday this week.
    Lee
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,133
    Quote Originally Posted by warrencox View Post
    That is where the term "stealer" comes from
    Sep 2006
    Chester
    71
    Hi Lee, sorry to hear you are thinking of cancelling your new order mate .
    Firstly, as mentioned above, do you definitely need a new turbo? It could be worth a second opinion. There is good independent near Chester called QRSport (www.qrsport.com) so it might be worth ringing them about it - I am sure if you have to pay for it out of your own pocket they will be cheaper than a dealership.
    Secondly you may have a good chance of getting Audi to pay for this depending on circumstances such as mileage and how far it is out of warranty. The Sale Of Goods Act gives you rights for up to 6 years and if the turbo has failed unreasonably early you may have a good chance at getting Audi to foot the bill. I don't have any legal background but I would try that route myself, perhaps ringing Audi UK and explaining the situation, mentioning the fact you are a long term customer and have a new one on order.
    S3 S-tronic Black Edition MY11 - buckets and other toys
    Not anymore - Back 2 BMW (shh)
    Aug 2006
    Norwich, Norfolk
    357
    You get treated like this and with a failure like this and you're happy to buy another one?!?!
    Would suggest you speak to Audi UK and ask them to get out their dictionary and lookup "goodwill"...
    BigBird's Avatar
    Lost in music...
    Mar 2009
    West Lancs
    379
    +1
    I maybe a bit late here, but I was also part of the "main dealer overboosting = new turbo" rip off club. I'll keep it short...
    My old Golf GT TDi 150 was overboosting. Dealer said new turbo. Took it to my local independent (Fuel Injection Services in Burscough Nr Ormskirk, Lancs) who got the turbo cleaned up & reconditioned down the road at Garrett. It apparently had a poor oil circulation that they sorted out. Didn't even cost me anything for the refurb - just charged me for the time to remove the turbo. Somewhat cheaper than the 1700 for the new turbo ex VW.
    Just another example where it ain't necessarily the tubo that's shot. And a great independent that time & again gets my business as they know what they're doing...
    132
    Another vote for seeing an independent dealer, see if there are any good ones in your area.
    A3 3.2 S Line DSG
    A3 TDI S Line DSG Gone
    Update on A3/TT 3.2 V6 software update: See this post
    L33TAY's Avatar
    Jul 2006
    Cheshire
    344
    I'll go back to Audi on Monday ant test the water with them, if they are not playing ball I'll cancel the order and try to find an independant garage for a second view
    It is driving fairly normal at the moment, its just that there isn't as much there low down in the revs, and the turbo whistle is loud.
    I'm just concerned that it will do the 'loss of power' thing again when I am miles from home, and it stuggles to start when cold, not sure if thats anything to do with it either?
    Thanks for the details of the different garages too, that may come in handy!!
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    If you can hear the tubo whistle you have blown a turbo air pipe off mate!!!
    Open the bonnet and get somebody to rev the engine whilst you try and locate the area from the noise then check out any vacum pipes or main turbo air pipes in that location
    you may get lucky and just cost a jubilee clip or a quick turn of a screw driver!
    Gaz
    Black 996 C4S
    B6 S4
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    Quote Originally Posted by gaz m View Post
    Gaz
    is that just for the TDI's or for any of the turbo A3's including the S3's as i can really hear the turbo on mine?
    Jan 2007
    central scotland
    82
    just replaced my daughters pd150 golf tubo mate , the bearings were away in it , sent it of to turbo technics to get it checked but it was fooked , got a recon one from them for 411 , car is now better than its ever been , drop me a pm if you need any help mate , regards alan
    Sarah's A3's Avatar
    5,923
    Quote Originally Posted by L33TAY View Post
    Which Audi Dealership are you dealing with??? I know an ace Independant in Ellesmere Port, they have helped me out sooo many times.
    Mar 2009
    Staffordshire
    1,241
    Quote Originally Posted by Sarah's A3 View Post
    Hi Sarah,
    What's this independents name? Worth knowing as they aren't too far!
    Cheers,
    Scott
    Sarah's A3's Avatar
    5,923
    Quote Originally Posted by Scott View Post
    Hi Sarah,
    Cheers,
    Scott
    Scott, its Central VW Audi
    http://www.centralvwaudi.com/
    Ask for either Simon or Peter, they are unbelieveably helpful and knowledgeable!
  28. #27
    gaz m's Avatar
    Sep 2009
    NORTH WEST
    148
    Quote Originally Posted by jungleman View Post
    If you can hear the turbo whistle, ie a rising/ falling whistle inline with the rise and fall of engine rev's then a turbo air hose or vacum house has popped of or not very tight fitting to whatever it should be fixed to so you can hear the air escaping.
    Dosent matter if petrol or diesel you should not hear the turbo whistle at all. Check it out and maybe just tighten all the turbo pipe clips to be safe.
    There are no mechanical bearings inside a turbo unless it is a very expensive roller bearing type. The turbo shaft actually sits and spins in the oil inside the thurst housing, There is an oil seal called the thrust bearing but it is not really a bearing it just keeps the oil around the turbo shaft, If this bearing is begining to fail you will see blue smoke from the exhaust and possibly a greating noise from the turbo (metal to metal) from this point on failure will be very quick.
    Hope this helps a bit more. Gaz
    Black 996 C4S
    B6 S4
  29. #28
    jungleman's Avatar
    Mar 2010
    SW London
    2,051
    ill have to get my head under the bonnet then hand have a little tighten
    are the turbo hoses easy to spot?
    Paolo
  30. #29
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    On a previous car (TT225) i had a boost leak, i went to http://www.panelcare.co.uk/index.php in Rochdale who did a boost leak test (takes 10-15 mins) and when the system is pressurised any leak is shown by smoke comming from that area
    I think it was matbe 30 for the test
    The owners son is active on various VW, SEAT, etc forums - CupraJake
    2.0 TDi 140 S-Line With - S3 Vents l S3 Alloy Pedals l S3 Gearknob I Aero Rear Wiper l X-Treme Bulbs l 09 Rear Lights l Custom Floormats l 18" TTS reps l LCR Splitter I Facelift Stereo
  31. #30
    L33TAY's Avatar
    Jul 2006
    Cheshire
    344
    Hi Gaz
    Is it easy to get to these pipes, I have had a look under the bonnet and wouldn't know where to start.
    I've not got a resolution with Audi yet as have not been in to them this week, will see If I can get them to sort it FOC next week.
  32. #31
    Jun 2003
    World of my own
    9,813
    Another great advert for longlife oil. Please please people get your turbo's off the sludge and onto fixed intervals with oil change at least every 10k.
    Alex Turner
