Sky InsuranceEM Tuning
Results 1 to 9 of 9
    A3matt's Avatar
    Mar 2010
    Worcester
    37
    How to open the boot with out the key fob?
    i have no battery on my car......how do open the boot without the key fob? on the audi a3 sportback 2006
    Hellz's Avatar
    Geordie Racer
    Apr 2009
    Newcastle
    372
    You can only open it from the inside I believe, there should be a latch inside to release the boot lock.
    AUDI S3 2007 Dolphin Grey
    PREVIOUS:
    AUDI A3
    3.2 V6 Quattro S-Line DSG
    AUDI S3 8L
    AUDI A3 1.8T Quattro
    8L
    KRL
    KRL's Avatar
    Jul 2007
    523
    Take the back seats down? Not sure of any other way.
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    Oct 2008
    133
    Use the button on the drivers door to disable all door locks. Then press the micro switch on the tailgate handle?
    Dec
    Oct 2009
    Colchester, Essex, United Kingdom
    318
    Quote Originally Posted by Hellz View Post
    How do you do this? never seen a boot release inside the car, unless it's because mine is an older 04 plate.
    '04 A3 2.0 TDI.
    consilio's Avatar
    Up the owls!
    Aug 2007
    Northamptonshire
    659
    Quote Originally Posted by Paul_c View Post
    This would only work with a battery, which the OP does not have
    March 2011 - B8 Audi S4, Ibis White, S-Tronic, Leather / Alcantera Super Sports Seats, Heated Front Seats, Advanced Key, Tech Pack High, Electrically folding and auto dimming mirrors
    SOLD - 8P Audi S3. Brilliant Black, FBMF wheel, Bose, RNS-E, Auto lights/wipers, Cruise control, Tyre pressure monitor, Parking sensors, Interior light pack, GSM phone prep, Armrest, Privacy glass, Electrically folding mirrors.
    scottie123's Avatar
    Oct 2008
    1,888
    You will have to climb through into the boot.
    Have a look at the rear tailgate from inside, and central near the bottom of the tailgate, you will see a blank plate about 25mm square. Pop this out and it should give you access to manually over ride the boot catch.
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    All other Audi's have boot release button in the car apart from A3's
    Never understood this
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
    Sep 2009
    Hi
    On the 3 door, if you get in the car, lower the rear seats, there is a horizontal slot about 3ins long in the boot trim panel.
    Put your ignition key into this, and slide one way or the other (can't remember which way) and the lock will open.
    I have a 2005 3 door 2.0T and have had to remove the door trim to sort out a leaking rear wiper motor.
    Hope this helps
    voxy53
