AH FabricationsEM Tuning
Results 1 to 20 of 20
    c_w
    1,050
    How to stop dash lighting up when the headlights are OFF? VAGCOM?
    I've notice a curious thing with the A3, it may be a common thing with VAG cars I'm not sure; the dash (speedo etc) cluster lights up on it's own and it makes it appear that you have turned the lights on (or is it always lit up, just that in the day you can't see it?? Though I'm sure sometimes its not lit up in slightly duller conditions). It seems a strange thing to me, since why would you want the dials lit up without headlights on, as it makes you assume you have lights on!
    Our previous car had auto lights, so at dusk the lights would come on and so would the dash lights. As far as I can see the Audi doesn't have auto lights but you could be mistaken to think you had lights on because the dashboard (speedo/rev etc) is lit up even though you have no lights on! Can this be altered perhaps in VAGCOM? so that the dash never lights up unless at least side lights are switched on?
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    I prefer the dials lit up, so i often drive with my sidelights on
    I'm sure there must be something in VAGCOM to change it
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
    c_w
    1,050
    Quote Originally Posted by smudge_don View Post
    But atm they are lighting up with no lights on at all!? Hopefully there's vagcom setting for it!
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    Quote Originally Posted by c_w View Post
    I'd prefer that!
    I'll be back!!!
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    This is a translation from the OpenODB website created by Sebastian Stange (some English info but for the Cluster Info I have had to use GoogleTranslate, to translate from German to English).
    (Instrument cluster
    Steuergert Codierung
    Control Module Coding
    STG 17 (Kombiinstrument) auswhlen
    STG 17 (instrument cluster) select
    STG Codierung -> Funktion 07
    STG coding -> Function 07
    00??xxx : Restcodierung
    00?? Xxx: residual coding
    +01 - 2-te Tankkennlinie bzw. Quattrocodierung
    +01 - 2-th Tankkennlinie or Quattrocodierung
    +02 - Highline ohne FIS (fr Midline - Automatik ohne FIS)
    +02 - High Line without FIS (for Midline - Automatic without FIS)
    +04 - Handschalter bzw. Kupplungsfahrzeug (nicht Midline)
    +04 - Handset or vehicle clutch (not midline)
    00xx?xx : Lndervariante
    00xx xx?: Country version
    0 - Deutschland (D)
    0 - Germany (D)
    1 - Rest der Welt (RdW - Linkslenker)
    1 - Rest of World (ROW - left handed)
    2 - USA (US)
    2 - United States (U.S.)
    3 - Kanada (CDN)
    3 - Canada (CDN)
    4 - Grossbritanien (GB - Rechtslenker)
    4 - Great Britain (GB - RHD)
    5 - Japan (JP - Linkslenker)
    5 - Japan (JP - LHD)
    6 - Arabische Staaten
    6 - Arab States
    7 - Australien (AUS)
    7 - Australia (AUS)
    8 - Rest der Welt (RdW - Rechtslenker)
    8 - rest of world (ROW - right hand drive)
    9 - Japan (JP - Rechtslenker)
    9 - Japan (JP - RHD)
    00xxx?x : Gurtwarnung
    00xxx? X: Seat belt warning
    keine Gurtwarnung
    No Seat belt warning
    Gurtwarnung Europa-NCAP
    Seat belt warning Euro-NCAP
    Optische dauerhafte Warnung, Akustische Warnung fr 91 Sekunden aktiv.
    Optical permanent warning, Audible warning for 91 seconds active.
    Gurtwarnung USA und Kanada alt
    Seat belt warning USA and Canada old
    Optische und akustische Warnung fr 6 Sekunden
    Optical and acoustic warning for 6 seconds
    Gurtwarnung USA und Kanada NAR neu
    Seat belt warning USA and Canada, new NAR
    Optische dauerhafte Warnung, Akustische Warnung alle 30 Sekunden
    Optical permanent warning, Audible warning every 30 seconds
    Gurtwarnung Europa-NCAP (einschl. Beifahrer)
    Seat belt warning Euro-NCAP (incl. passenger)
    Gurtwarnung USA und Kanada alt (einschl. Beifahrer)
    Seat belt warning USA and Canada old (incl. passenger)
    6
    6
    Gurtwarnung USA und Kanada NAR neu (einschl. Beifahrer)
    Seat belt warning USA and Canada NAR new (incl. passenger)
    00xxxx? : Beleuchtungsoptionen
    00xxxx?: Lighting Options
    Hinweis : Die Optionen 4-9 stehen erst ab MJ 2005 zur Verfgung.
    Note: Options 4-9 are available only from MY 2005.
    Ab MJ 2005 ist bei den Optionen 0-4 ist die Kontrolleuchte fr Standlicht AUS und bei den Optionen 5-9 ist die Kontrolleuchte fr Standlicht EIN.
    From MY 2005 is at the options 0-4 is the parking light warning light OFF, Options 5-9, the indicator light for parking lights ON.
    0 - Zeiger und Skalen AUS (bei Kl.15 Ein und Kl.58 Aus)
    0 - pointers and scales off (at a terminal 15 and Kl.58 Off)
    1 - Zeiger EIN, Skalen AUS (bei Kl.15 Ein und Kl.58 Aus)
    1 - A pointer, scale OFF (at terminal 15 A and Kl.58 Off)
    2 - Zeiger AUS, Skalen EIN (bei Kl.15 Ein und Kl.58 Aus)
    2 - hands off, scale A (at a terminal 15 and Kl.58 Off)
    3 - Zeiger und Skalen EIN (2. Dimmkennlinie - Kl.15 Ein / Kl.58 Aus)
    3 - pointers and Scales ON (2nd dimming characteristic - terminal 15 A / Kl.58 Off)
    4 - Zeiger und Skalen EIN (ohne 2. Dimmkennlinie - Kl. 15 / Kl. 58 Aus)
    4 - A pointer and scale (2nd dimming characteristic - Cl 15 / Cl 58 from without)
    5 - Zeiger und Skalen AUS (bei Kl.15 Ein und Kl.58 Aus)
    5 - Pointers and scales off (at a terminal 15 and Kl.58 Off)
    6 - Zeiger EIN, Skalen AUS (bei Kl.15 Ein und Kl.58 Aus)
    6 - A pointer, scale OFF (at terminal 15 A and Kl.58 Off)
    7 - Zeiger AUS, Skalen EIN (bei Kl.15 Ein und Kl.58 Aus)
    7 - hands off, scale A (at a terminal 15 and Kl.58 Off)
    8 - Zeiger und Skalen EIN (2. Dimmkennlinie - Kl.15 Ein / Kl.58 Aus)
    8 - Pointers and Scales ON (2nd dimming characteristic - terminal 15 A / Kl.58 Off)
    9 - Zeiger und Skalen EIN (ohne 2. Dimmkennlinie - Kl. 15 / Kl. 58 Aus)
    9 - Pointers and Scales ON (2nd dimming characteristic - Cl 15 / Cl 58 from without)
    Steuergert Anpassung
    Control adjustment
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    c_w
    1,050
    Thanks, looks like it could be a setting in that last block!
    56
    This may guide you to the options
    http://www.audi-sport.net/vb/showthr...hlight=cluster
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    i think i heard that there is a light sensor at the cluster so when it gets dark outside it (in a tunnel) will light up briefly so that you can see the dash. I dont have the auto rain/lights pack but i notice that the cluster lights up for a few secs when i go into a tunnel, but if i am in a long tunnel it just goes dark after a while and i only have the red dials lit up. I actually prefer the lights to come on and am now thinking of getting the auto lights/rain sensor installed.
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Lights Pack
    MODS:
    S3 facelift, 19" RS6, RS3 Grill, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, S3 brakes, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, Auto Folding & Dimming Dumbo Mirrors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    Items for Sale
    Read My Blog & Build Thread
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    934
    Yes there is a light sensor in the speedo, when the ambient gets a bit dark it will light up the dash lighting. The lights stay off until you see the green headlight icon lit up on the cluster.
    Hope that helps.
    VCDS USER
    c_w
    1,050
    This makes sense as sometimes I've noticed the dash not lit up and then sometimes is, must depend on the lighting conditions. However, my car does not have auto lights so I think it's a bit of a strange setup.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    you can also set what you want lit via vagcom, ie if you dont want the needle lit when your sidelights are on
    kkp0897's Avatar
    Sep 2009
    Essex (Boy)
    553
    Apologies for the thread hijack but anyone know how to code the instrument cluster not to light up until the headlights are turned on? They are on from when the ignition is turned.
    I have auto lights and my query is related to MY2010
    You can take the boy out of Essex but not Essex out of the boy...
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,850
    Quote Originally Posted by kkp0897 View Post
    Your car is coded like that from the factory but it can be changed in vcds. Not sure why you would want to though if you have Auto headlights...
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Audi Heaven
    Somerset
    1,850
    Quote Originally Posted by SAiLO View Post
    Hope that helps.
    Its actually the other way around. When the ambient light drops the dials go dark so the driver know to turn the lights on...
    Scott
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,289
    you go into the instrument cluster coding and change the last number to 3 to make it dim at night to remind you to turn on the lights
    code it to 4 to have the lights permanently on
    A3 Sportback 2.0TDI
    MODS:
    Items for Sale
    Mar 2012
    Cumbria
    91
    Iv set mine do that the needles are always lit, I like seeing the needle sweep at night with just the needles lit!
    kkp0897's Avatar
    Sep 2009
    Essex (Boy)
    553
    Quote Originally Posted by audicruiser View Post
    Thanks,
    Apologies if ive not made myself clear... Yes I have auto lights so when lights turn on automatically so should the instrument cluster backlight.... However in my case (and from factory) instrument cluster back light is on permanently and What i want is only the instrument cluster to turn on when lights are (automatically) turned on.
    Audi Heaven
    Somerset
    1,850
    Needs to be set as per Ash's post above then... Change the 4 to a 3.
    Scott
    davc's Avatar
    Foursprung Duck Technik
    Jan 2013
    Caledonia
    188
    I have auto lights and it does this even when the switch is set to auto. Is this normal?
    I would've thought that if the lights were set to Auto with just the DRL's on, that when the light fades, the cluster wouldn't go dark as the dipped lights would be activated automatically?
    MY'09 S3 Sportback |Gloss Black Mirrors |Buckets |Black Optiks |Open Sky |A good few other bits and bobs
    c_w
    1,050
    I'm not sure but the combination of dials being lit and DRLs causes issues IMO. Just last night I'm on the motorway at 8pm and 5-series in front with no (tail) lights on. Driving alongside I can see his dash fully lit and his LED DRLs blazing at the front (so he can probably see the reflection of these on cars in front so assumes they're on).
    But as we know DRLs, especially LED ones from AUDI/MERC/BMW/CITREON/PORSCHE etc are very bright and blinding at night/dusk. Surely it should be law (much like the HID having to have levelling/washers) that cars fitted with DRLs must have auto lights that switch on normal/proper lights at dusk/dark??
