Badger5EM Tuning
Results 1 to 7 of 7
Thread: Door problem!
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Angry Door problem!
    The passenger door on my car is catching when open/shutting.
    I've managed to narrow it down to the actual door lock and where it meets the catch that is attached to the car body.
    It looks as though either the lock is slightly too low or the catch is slightly too high. Only by millimeters thoughs.
    I don't think the door is out of position as all the gaps look equal and pretty much the same as the driver's same.
    Looked to see if there is a way to adjust either the lock's position or the catch's position but it needs a multipoint screwdriver sort of thing to loosen the bolts?!
    Anyone know the extact tool required to loosen these and where I might be able to pick one up?
    Also, anybody ever mucked about with either the lock of the catch before??
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    Usually if the door has not dropped, you adjust the catch on the body of the car. I've not done it on my A3 but usually it would be a Torx bolt holding the catch in place (can't confirm that as the A3 is at home).
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Here are some pics of the bolts in catch and door lock (the last two are taken sideways)...
    Feb 2007
    Hampshire
    1,654
    The adjustment is definately done on the catch side and not the door lock, the lines are reference points when adjusting them.
    Pretty sure that is the same as the Golf and a Torx bolt.
    I will take a look at mine tonight.
    Paul
    VCDS HEX-USB+CAN
    prt57's Avatar
    Dec 2006
    243
    In order to work out if the catch on the body work needs to go up or down, shut the door with some downwards pressure and then some upwards pressure. One way should make the problem worse and the other easier due to slight tolerances in the hinges.
    Mark the original position of the catch on the bodywork with pen on something like white electrical insulation tape as when you loosen it it may move down on its own and then you need a reference point to get it back to where you started.
    It is also worth putting a tiny bit of grease on the catch.
    prt57
    AR-CoolC's Avatar
    Sep 2009
    Lincoln
    24
    They're called Multispline (sometimes called tripple square) bolts, either M6 or M8, I can't remember exactly off the top of my head.
    Like these
    http://cgi.ebay.co.uk/MALE-MULTI-SPL...-/260549473881
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,223
    Quote Originally Posted by AR-CoolC View Post
    Like these
    Spot on. Cheers mate.
