Monster MotorsportVolks Autos
Page 1 of 2 12 LastLast
Results 1 to 40 of 63
Like Tree1Likes
Thread: I've read the guides but for f**k sake, how do you get the engine cover off?
    Aug 2005
    London
    263
    I've got the 2.0 TFSI and have read a number of guides on how to get the engine cover off but it just won't budge.
    I've tried running the engine and even driving on a dual carriage way to warm it up but I still can't the b*stard off. I've found where the rubber grommets are and simply can't get the cover loose.
    Any tips?
    Surely the Audi garage doesn't have this problem. Do they have a special tool?
    Thanks for any help in advance
    Oct 2008
    888
    start with one corner and give it a big yank.
    Aug 2005
    London
    263
    I've tried every corner and given them all a bloody big yank, so much so I actually lost my footing and fell over much to the amusement of the passing pedestrian
    Oct 2009
    99
    Imagine its a bloke cracking on to your lady in a club and your gonna wrestle the b*stard off ......imagine this and then some and voila !! lol
    Took me around half an hour to get mine off then a half hour lie down before i started fitting my ITG !!
    Once off stick a bit of ''lube'' on the grommets for next time .
    SILVER S3.......GIAC ECU & FLASHLOADER.....ITG INTAKE.....SACHS ORGANIC CLUTCH........ROLLING @ 328bhp...321lbs/ft
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    You have to use a special tool:
    8P2 S3
    Oct 2008
    888
    or a bit of muscle
    jsws3's Avatar
    Oct 2009
    443
    Get in the gym and pump them guns up and the come back to the car and give it a good pull .
    It should come off mine come off a peice of cake
    Oct 2008
    888
    Ask yer Mum to do it, mums are hard as fook
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    LOL @ some of the comments on here - haha
    as said previously just pull it off! - if it hasnt been off in a while then it might just need that extra force!
    Audi A3 2.0 tdi sport..many mods to follow...just too fussy when it comes to making decisions!
    Aug 2005
    London
    263
    alright alright, I take the hint, give it a tug
    any other 'helpful' tips?
    27,007
    Ok well from my 8P TDI cover, give the front a lift up as it has 2 pillars/ball joints its pushed down onto, then top right corner also has a pillar, now on mine the lid also has a fixing where it is hooked/pushed into a rubber fixing in the top left that you just pull/slide the cover towards the front of the car & then it should just lift out as long as the 3 pillar points are disengaged.
    This maybe helps a little, remember I'm quoting from a tdi not tfsi as pic shows.
    KrAzY K likes this.
    Aug 2005
    London
    263
    Its just the grommets won't budge
    Anyone know what Audi uses?
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    i have issues with mine, i tried to take mine off a while ago but ended up snapping something so i left it off, i was only taking it off to clean something iirc.
    Aug 2005
    London
    263
    Quote Originally Posted by RobinA3 View Post
    I want to try to avoid coughing up for a new cover if poss
    Will give it another go at the weekend
    warren_S5's Avatar
    Oct 2007
    7,133
    http://picasaweb.google.com/warrenco...19273398650034
    The first few times you take it off, its a nightmare as the rubber mounting grommets aren't worn.
    I did a basic guide of sorts in the link above when doing a DV change, but it wont offer you any more than what you've read earlier in the thread.
    pull it like you mean it ;-)
    Audi S5 3.0V6T Coupe Black Edition
    KRL
    KRL's Avatar
    Jul 2007
    523
    I had loads of trouble getting the engine cover off for the first time. No wonder VAG have changed the engine cover design for the 2.0 TSI engines as I am sure all the techs will have complained about the TFSI cover as it is such a pain to remove.
    Once you have removed it my top tip would be to lube up the rubber grommets with some molly grease which will mean it is easier to remove next time you try.
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    27,007
    Quote Originally Posted by davej_anderson View Post
    Blow torch
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    any luck with it?
    Aug 2005
    London
    263
    Quote Originally Posted by tdisportuk View Post
    any luck with it?
    Not yet, going to give it a go at the weekend. Am pretty sure I will posting a thread about how weak I am or that I've broken the ruddy thing
    Oct 2008
    888
    l would have went through a couple of shirts by now if l couldnt get it off. You got a picture of yourself? Just so we can see if your of the right stuff.
    Aug 2005
    London
    263
    Quote Originally Posted by dc240969 View Post
    I've heard of people like you on the internet, pretend to be your friend, ask for pictures, bugger you senseless
    tsk tsk, and I thought ASN was a nice place
    27,007
    Oh no, please dont start another gaylord thread, had enough of these the last 1-2 weeks on ASN, was starting to seem like www.gaysport.net
    Oct 2008
    888
    Ha haa. Only joking. lm sure your trying your best. If l where closer l would bring me Mum down.
    27,007
    lmfao classic lmfao, thing is if you did & she took the cover of in 10 seconds flat what does that say about Warren, lol
    Aug 2005
    London
    263
    Thanks. Am not going to post anything about your mum and her implied strength as I don't know you and I'm sure she is a lovely woman...
    ...with a moustache
    JOKE!
    Oct 2008
    888
    Twenty bags of shopping a week. l will get your cover off.
  28. #27
    27,007
    lmfao
  29. #28
    warren_S5's Avatar
    Oct 2007
    7,133
    a homo!
  30. #29
    27,007
    Oh no gaydar anyone lmfao
  31. #30
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    15 days to go
    8P2 S3
  32. #31
    scottie123's Avatar
    Oct 2008
    1,888
    Quote Originally Posted by Staz View Post
    15 days to go
    Until what staz?
    I'm intrigued!
  33. #32
    warren_S5's Avatar
    Oct 2007
    7,133
    and me
  34. #33
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,221
    Only if he is.....
    .....therefore meaning his mum is........
    Otherwise it ain't happening!
  35. #34
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    Quote Originally Posted by scottie123 View Post
    Until what staz?
    I'm intrigued!
    Until Nigel's site is up:
    8P2 S3
  36. #35
    warren_S5's Avatar
    Oct 2007
    7,133
    Bugger me, I won't be eligible.... I'm married
  37. #36
    scottie123's Avatar
    Oct 2008
    1,888
    Quote Originally Posted by warrencox View Post
    So was elton John
  38. #37
    27,007
    Says a man who goes by the names of: Stazalicious or Stazatron
  39. #38
    27,007
    So was elton John
    Buggered, think thats well known mate, lmfao
  40. #39
    Oct 2008
    888
    you got me nailed ayethree
  41. #40
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    Errrr yeah, and?
    8P2 S3
Tags for this Thread
