AH FabricationsVolks Autos
Results 1 to 7 of 7
    Gryphon001's Avatar
    Jun 2009
    303
    FSI vs TSI question
    I was just wondering about whether anyone has had the chance to directly compare the difference between the two in terms of engine and transmission... I just had the chance to take a drive in a friends A3 which is also '08 but has the TSI engine as opposed to my FSI. I found that his car was by far smoother than mine. Mine the engine is louder and rougher sounding almost like a diesel sometimes.
    Even when shifting, I have the Forge short throw shifter and 42draft design aluminum bushings on mine vs his stock shifter. I found that his shifts and clutch are almost buttery smooth. My clutch is jerky and harsh by comparison. Not sure if that could be an issue with my car somewhere or whether the updated engine is just that much different.
    Any input would be welcome.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,775
    Surely the main difference felt would be the turbo boost???
    Khufu's Avatar
    West coast of Scotland
    5,693
    The FSI has a similar sound to a diesel on idle though a quieter. You say yours is also a 08 plate, what size of engine have you?
    Khufu's Avatar
    5,693
    Quote Originally Posted by Boydie View Post
    did you still get NA petrol engines in 2008?
    Gryphon001's Avatar
    Jun 2009
    303
    The only engines available in North America are the 3.2L and the 2.0T gas/petrol... the TDI only got released in the A3 this year. I have the 2.0T engine and what I find is that it's the transmission/clutch that is the roughest. It just feels downright harsh, almost like a bit of a really fast stutter when engaging. It's not severe, but noticeable enough. The car is a daily driver and has only been track driven once on a low speed track. Not sure if all the cars feel the same or not.
    alpha3
    Miami,Fl
    11
    Quote Originally Posted by Gryphon001 View Post
    This came out some time ago in response to a similar question - there ARE big differences in the TSI-FSI comparison.
    This is some good info for US-spec engines; some of it may also apply to the UK. Courtesy APR:
    Engine Code: CCTA OR CBFA
    Type of Engine: Inline 4-Cylinder TSI Engine
    Displacement: 121 cu in (1984 cm3)
    Maximum Power: 200 hp (147 kW) at 5100 - 6000 rpm
    Maximum Torque: 206 lb ft (280 Nm) at 1700 - 5000 rpm
    Number of Valves Per Cylinder: 4
    Bore: 3.2 in (82.5 mm)
    Stroke: 3.7 in (92.8 mm)
    Compression Ratio: 9.6 : 1
    Firing Order: 1-3-4-2
    Engine Weight: 317 lb (144 kg)
    Engine Management: Bosch MED 17.5
    Fuel Grade: 95/91 RON
    USA - Exhaust Emission Standard: ULEV (CCTA) - SULEV (CBFA)
    Some major differences from the FSI to TSI include: - chain driven belt
    - fuel/engine management
    - components in the intake system
    - oil filter and oil dipstick relocated
    - improved PCV system (proved to be problematic in the FSI)
    - compression ratio lowered to 9.6:1
    - more balanced cam shafts in the center of the block on both sides
    - down pipe
    - fuel efficiency (debatable)
    - better emissions
    - more 02 sensors on exhaust system
    <img src=http://www.audi-sport.net/vb/./signaturepics/sigpic44631_3.gif border=0 alt= />
    alpha3turbo
    Miami,Florida, USA
    2009 A3 BLACKEdition,DSG/Titanium S-Line/Opensky/TFSI-Carbonio/APR1/VAGCOM user/
    ...an ill-tempered tigress..
    warren_S3's Avatar
    Oct 2007
    6,183
    Is it true that the fuel system is driven from the inlet cams on the TFSi, and from the exhaust cams on the TSi?
    Audi S3 Panther Black [2011] Build Thread
    Mods: Revo Stg2, Blueflame TBE, Eibach Pro springs, R8 oil cap
    On order: Audi S5 3.0V6T Coupe Black Edition, Phantom Black [Due 26 May 2014]
    Planned Mods: Revo Stg1+ with DSG map, Revo CAI, custom exhaust, H&R Trax spacers, EM Tuning LED interior lights, R8 oil cap, Porsche coolant & brake fluid cap
