Volks AutosSky Insurance
Results 1 to 24 of 24
    geraint.davies's Avatar
    May 2009
    48
    Cruise Control Fitting
    Just a quick one, am I right in thinking that in order to fit the cruise stalk the steering wheel will need to be removed?
    2008 Ibis White S3
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Steering wheel
    Slip ring
    Lower steering wheel cowl
    Steering wheel ECU
    All have to be removed
    You will invalidate your steering wheel ECU warrenty though as you have to clip it out - in order to do this, you must tear the yellow warrenty tape.
    You then just pull the old stalk out with the aid of a small screwdriver - be carefull not to damage the the white float switch on both removal and replacement - mine broke fitting cruise and had to use the original on the non cruise stalk
    May 2009
    48
    Cheers, thought so. Don't have time for that now and off away for the weekend tomorrow so will have to wait until next weekend.
    2008 Ibis White S3
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    You also have to program it in via vagcom/VCDS
    david_phillips95's Avatar
    Nov 2008
    538
    Quote Originally Posted by Boydie View Post
    Steering wheel
    Slip ring
    Steering wheel ECU
    I never had to change my ECU, you can check your ECU version using VCDS and then quote the ECU number to Audi and they will order you the retrofit kit this includes everything you will need e.g. stalk and the lower steering cowel. As your car is 08 you should be ok. My car is an 07 and my ECU was fine.
    Cheers Davie
    Spin140's Avatar
    Mar 2005
    Derbyshire, England
    2,013
    My car is a 2010 car and Matt Andrew kindly fitted cruise to mine last night, as far as I know it just involved the new stalk and coding, works a treat, big thankyou to Matt, all completed in less than an hour.
    Wife - 12 BMW 320D 181 bhp, 8 Speed Auto, Melbourne Red, Heated Leather, privacy.
    10 S3 SB, Phantom, Buckets,Int light Pack, Privacy. (Sold)
    Golf GTi MK6 - Revo stage 2, ITG, Milltek Race TBE, AP Racing 4 pot BBK - Sold.
    10 S3 SB, Phantom, Buckets,Int light Pack, Privacy,Nav, Park sensors, 6 disc, Revo Stage 1, ITG Enclosed Intake - Sold
    BMW M135i F20 - Bloody good straight from the box !
    "Fast Cars are Safer...."
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    I am 95% sure the ECU box has to come out to fit the new stalk..... will confirm
    Nov 2008
    538
    I never removed my ECU box when i done mine
    Davie
    matt123890's Avatar
    Apr 2010
    Bristol, UK
    67
    Hi guys sorry for bringing up an old thread but have been searching for hours and cannot find the answer!
    if you dont have to removed the steering ecu do you have to take off the steering wheel and the slip ring ?? Can it not be a simple as pluging in a new stalk and abit of coding?? sorry havent had chance to remove the bits and have a look myself !
    Matt
    Audi A3 8P Sportback 2.0T FSI, Silver.
    Mods:
    18" new style RS6 Reps, Audi rubber mats, Centre armrest, vortex spoiler,Detachable Towbar,Cd changer,Coming home leaving lights, Double Din Conversion with new sleek MY11 buttons And 2010 RNS-E
    Mods to do:
    S3 front bumper, Private Reg
    Boydie's Avatar
    Boycie
    Dec 2006
    4,814
    I mentioned in the second post above that you have to take the steering wheel and slip ring out.
    The indicator and cruise stalk are part of the one unit which slots into the steering column behind the steering wheel.
    It is dead simple to remove! 2 torque screws behind the steering wheel controls, remove air bag, unplug connectors to air bag, unscrew slip ring, 12mm spline I think (maybe bigger) to remove steering wheel, then pull at the stalk!
    matt123890's Avatar
    Apr 2010
    Bristol, UK
    67
    ok cheers boydie just checking as thought if i had right controller it maybe simpler !!
    cheer for clearing that up for me dude!
    Matt
    Mods:
    Mods to do:
    scottie123's Avatar
    Oct 2008
    1,888
    Does anybody know if this is the same process for changing the wiper/dis stalk ?
    27,096
    Yes for you should be easy mate.
    scottie123's Avatar
    Oct 2008
    1,888
    Cheers fella.
    You seen my pm yet?
    27,096
    Yes, in middle of downloading something, I will comment dont worry mate.
    heeman10's Avatar
    Audi driver since Dec 08
    Dec 2008
    Somerset
    388
    I have a suitable slip ring if you need one Drop me a PM if you do!
    .: 2005 Dolphin Grey A3 2.0 TDI Sport :.
    gynads's Avatar
    Oct 2009
    338
    I retro fitted FBMFSW & cruise last weekend, my car is an 07 S3. cruise was fine but after fitting it turns out i have a 'midline' steering wheel ECU, this supports cruise but unfortunately not MF. Either way as yours is an 08 it will be fine, but as Boydie says, the ECU had to be removed (along with steering wheel , and slip ring)
    EDIT: i had to activate cruise in 'Engine 01' as well as the other one (central electronics?) had me stumped for a bit.
    27,096
    Quote Originally Posted by gynads View Post
    Really, Boycie advised to remove the Engine Control Unit, you sure mate :P, assume you mean steering CU
    Aug 2010
    13
    Can anybody help me out with coding?
    Mine is 09+ A3 Euro 2.0T. I did all of the install (didn’t need to remove the Steering wheel ECU), but now i am stuck at coding. Can’t seem to be able to make it work. What other modules should i change coding except steering wheel module?
    Any help is appreciated.
    terrymcg's Avatar
    Nov 2006
    West Lothian
    236
    From memory I am sure you have to code the engine as well.
    57 Plate Imola Yellow S3
    gynads's Avatar
    Oct 2009
    338
    2) Enable the ECU for Cruise Control using VAG-COM or similar. Note that this procedure does not require the registered version of VAG-COM :
    *[Select]
    *[01 - Engine]
    *[Login - 11]
    *Enter 11463 to activate cruise control
    *[Do It!]
    (Procedure courtesy of Ross-Tech: Home)
    gynads's Avatar
    Oct 2009
    338
    I think on mine, it was not login, but security or something? Was straight forward once I found that.
    Aug 2010
    13
    Wow, thanks a lot. So Engine 01 and Steering wheel 14 are the only ones...... I am going to give it a try and let you guys know!!!!!!
    Aug 2010
    13
    Quote Originally Posted by danielescobarg View Post
    Just finished recoding and its now working.....But, i guess since my car is newer ECU MED17.5, the Engine 01 part was different. Coding II was blacked out, but coding I wasnt, i just entered thru long code helper and selected cruise control active, and that did the trick.
    Thanks anyways, now i can switch between programs with APR fully loaded ECU..
