Chris NottSky Insurance
Results 1 to 11 of 11
    bambam's Avatar
    Sep 2009
    South West
    123
    Gaining access to washer bottle/pump
    My rear wash wipe isnt working (pump makes noise but nothing comes out).
    I have taken the rear panel off the inside of the boot and there is no fluid in here.
    The pump makes a higher pitched noise when trying to operate the rear washer than when operating the front. This suggests to me that it is not picking any water up to send to the rear.
    Am I right in thinking both front and rear washers are fed from the same bottle?
    If so I need to gain access to the washer bottle/pump to identify whether water is being picked up from the bottle.
    So, how do I gain access to this?
    From the top or the bottom?
    It looks like a pain in the arse from the top as headlight needs removing...which seems to be wedged in by the bumper... (its a 2003 2.0 TDi).
    TIA
    smudge_don's Avatar
    Dec 2008
    Sutton, Surrey
    2,941
    Quote Originally Posted by bambam View Post
    TIA
    Front and back both use the same washer bottle mate, located under the bonnet in the engine bay
    Your problem is most likely that the hole where it sprays from on the rear wiper is blocked
    Try sticking a needle or something in the hole, see if that unblocks it
    Currently driving a 55 plate Ford Mondeo ST. But as Arnie once said...
    I'll be back!!!
    bambam's Avatar
    Sep 2009
    South West
    123
    Tried that and unfortunately no joy...
    Mar 2009
    120
    I have the exact same problem Tried with wd40 and nothing...
    If I activate the rear wiper it sprays the remaining fluid... After that it stops No leaks in the car....
    bambam's Avatar
    Sep 2009
    South West
    123
    Quote Originally Posted by drsilviuro View Post
    I get nothing from the washer jet but can hear the pump making a higher pitched noise to normal which suggests its not picking up fluid.
    Thought/hoped it would be something easy to spot if I could get to the washer bottle/pump arrangement to see whats going on...
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Same problem with mine - I took the small black plastic jet off and then tried the rear washer......and it worked.
    I soaked the small black plastic washer jet in limescale remover for a few hours and then rinsed it and it's been fine ever since.
    Jon
    Now A3 less......
    bambam's Avatar
    Sep 2009
    South West
    123
    Quote Originally Posted by redbutcher View Post
    hmmm, i'll give this a try then before messing with looking at the pump/bottle
    cheers
    JohnS3's Avatar
    Oct 2004
    3,021
    You have to remove the bumper skin and maybe pop the drivers headlight out to get to the washer pump.
    tdisportuk's Avatar
    Mar 2009
    UK
    459
    as said previously! bumper off job!
    located on the drivers side
    Audi A3 2.0 tdi sport..many mods to follow...just too fussy when it comes to making decisions!
    Mar 2009
    120
    Thanks! That was in my case too! Removed plastic washer jet and cleaned it.. and it now works!
    bambam's Avatar
    Sep 2009
    South West
    123
    I'm still yet to find time to take a proper look at mine...will definitely be giving this a try first though
