Badger5Volks Autos
    EvolutionV's Avatar
    Feb 2009
    Lancashire
    199
    Heated Seats Not Working !!! HELP!
    Got the kufatec cable through the post this morning so i wired it up but heated seats don't seem to work.
    Did a scan with vag com and this came up. Any ideas. Thanks in advance
    Tuesday,06,April,2010,21:31:13:59634
    VCDS Version: Release 908.2
    Data version: 20100326
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Control Module Part Number: 8P0 820 043 AD HW: 8P0 820 043 AD
    Component and/or Version: KlimavollautomatH19 0360
    Software Coding:
    Work Shop Code: WSC 00000 000 00000
    2 Faults Found:
    01856 - Temperature Sensor for Heated Seat; Right Front (G345)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 183
    Mileage: 28852 km
    Time Indication: 0
    Date: 2010.01.13
    Time: 00:07:33
    Freeze Frame:
    Temperature: 3.5°C
    01855 - Temperature Sensor for Heated Seat; Left Front (G344)
    Freeze Frame:
    Khufu's Avatar
    West coast of Scotland
    5,693
    Are you just testing them or is everything all wired in place? Sounds like the temp sensors in the seat arent wired in or correctly wired?
    EvolutionV's Avatar
    Feb 2009
    Lancashire
    199
    Its all wired in place. Yeah i was thinking it must be the temp sensor thats isn't connected up properly? I've checked all the wiring again and its all at the right pin outs so it should work?
    If i knew what pins on the back of the climate control go to the seat temp sensors i could check them. Is there anyway of finding out?
    Here's the instructions i got from kufatec:-
    Manual wiring heated seats Audi A3 8P
    Please disconnect the battery before starting installation.
    Please wire the loom starting from the seats to the following connections:
    Wire configuration:
    Red/ White – Steady plus - Fusebox
    Wires (Gray) on the opposite needs to be connect to the climate control
    Connector D PIN 13, 14
    Brown – Ground point A-coloumn
    White – climate control connector D PIN 2 (if taken connecting by soldering)
    Blue/ Yellow – climate control connector C , PIN 10
    Blue/ Red – climate control connector C, PIN 9
    Gray with Yellow mark (tull) – climate control connector D, PIN 5
    Gray with Red mark (tull) – climate control connector D, PIN 6
    EvolutionV's Avatar
    Feb 2009
    Lancashire
    199
    bttt
    Khufu's Avatar
    5,693
    had quick look, but might depend on year, this was for 2005:
    G344 is the temp sensor
    T4p is driver 4 pin connector
    T4q is passengers side 4 pin connector
    T16d is black 16 pin connector on aircon unit
    T16e is brown 16 pin connector on air con unit
    Driver: T4p/3 -> br/ws -> T16e/10
    T4p/4 -> sw/ws -> T16d/2
    Passenger : T4q/3 -> br/sw -> T16e/9
    T4q/4 -> sw/ws -> T16d/2 (same one as above - wires join together)
