Volks AutosMonster Motorsport
    Haz1's Avatar
    May 2009
    Glasgow
    232
    Stage 3 remap instead of stage 2+
    Hi all
    I have a situation due to the MTM remap. MTM don't make a stage 2+ remap like revo do so considering that I have a full turboback milltek exhaust and a uprated MTM panel filter, I was thinking of getting a autotech fuel pump. So if I install the autotech fuel pump and load the MTM stage 3 remap which is designed for the big turbo kit, which problems Im I likely to experience or would it work perfectly fine?
    Haz
    Audi S3 8P2 | Merlin Purple | Black Optics | Recaro Bucket Seats | Privacy Glass | Bi-Xenon Adaptive Headlights | Bluetooth Phone Prep. | MTM Stage 2 | Milltek TBE | ITG Stage 2 Induction Kit | Odyssey Racing 40 Battery | Rev D DV | Denso IK24 Spark Plugs | RS4 Pressure Regulator Valve | TTS Engine cover | To do: Autotech HPFP
    Mar 2008
    Bradford, WY
    788
    well you've kind of answered your own question. First of all your clutch wont last a day with Stage 2+ or 3. Your turbo wont be able to produce the required boost pressure causing failure with stage3. You also need a cold air induction kit, not panel filter. Intercooler is required of you want to make full use of a bigger turbo. And some use rs4/r8 injectors with stage3. Aw ye and you'l probably want some bigger brakes to stop all this power
    A3 2.0 TDI Optics Black S-Line, FR&RTuning Stage 3! GT20 Hybrid Turbo, THS TFSI FMIC, Sachs performance clutch kit+SMF, Milltek 2.5" Turbo-Back Non-Res Exhaust, ITG Maxogen Induction, EGR Delete with FR&RTuning Map out, Custom Black 18" RS4, 35mm H&R springs, S3 brakes, EBC Yellowstuff, front splitter, HID Xenons, S3 tailgate Spoiler, 09 Rear Lights, Retrofit Audi Ipod, S3 Air vents, Bose sound+retrofit JBL Subwoofer 1200W.
    Milltek Cat-back Non-Res for S3 2.0T FOR SALE both 3dr and 5dr PM
    Oct 2009
    99
    I would look at getting a full intake system first to compliment your Milltek, such as the ITG (which i have) or the Forge,Evoms etc.
    Massive difference !
    SILVER S3.......GIAC ECU & FLASHLOADER.....ITG INTAKE.....SACHS ORGANIC CLUTCH........ROLLING @ 328bhp...321lbs/ft
    Haz1's Avatar
    May 2009
    Glasgow
    232
    Quote Originally Posted by CJ3BLUE View Post
    Im definitely going to get a proper induction kit, thinking between the ITG and Forge Twintake, then thinking of the Autotech fuel pump. But with a stage 2 map only (not stage 2+) I reckon I wouldn't be getting the full benefit of the CAI and uprated fuel pump setup?
    Oct 2009
    99
    Imo your not getting the benefit of your exhaust at the moment because your still getting a standard air flow into the engine with the oem setup,when you fit a intake the volume of air the engine pulls in is massive (ITG has a 3'' internal bore pipe!! ) i seriously couldnt see how it would fit in the engine when i opened the box lol !
    Ive done the opposite ive got the massive air flow going in and still have the restrictive exhaust causing back pressure.
    The guys @ Star-performance said before i get the exhaust he recommended i got the fuel pump done first.
