audi a3 can bus adapter setting
hollows wife
south yorkshire
changed over from the audi stereo to an aftermarket one , bought the connects2 canbus adapter not the universal one .
problem i have is the original stereo as you know turns off when you remove the key from the ignition .
with the adapter the stereo turns off when the key is below acc position2 (i.e all dash lights are on )
wouldnt mind but if you just want the stereo on when you pull up somewhere you have to turn ignition off to turn engine off then turn the ignition back to position 2 just for the stereo .
its starting to get annoying now
anyoine else use one of these and have same problem ??
